I am trying to figure out how to reprogram the code on my craftsman keyless entry pad model number 139.53876.Does anyone have a clue
Moved into a new house and don't know how to change the keypad...any thoughts?
Hello - we have a craftsman model 139.53684 and these are the instructions for setting the personal entry code - (you will need two people doing this) To set the code using the Premium control console: 1 Enter a four digit personal ID # of your choice on the keypad then press and hold ENTER. 2 While holding the ENTER button, press and hold the LIGHT button on the premium control console (the premium control console is the main opener button mounted in the garage probably near your door) 3 Continue holding the ENTER and LIGHT buttons while you press the pushbar on the premium control console (now all theses buttons are held) 4 When the motor units lights blink Release buttons - it has learned the new code. If bulbs are not installed you will hear two clicks. To set the code using the 'LEARN' button (you will need a ladder & two people doing this) you used the learn button to set the new remote. 1 press and release the learn button on the motor. The learn indicator light will glow steadily for 30 seconds 2 within 30 seconds enter a four digit personal ID number of your choice ob the keypad then press and hold the ENTER button 3 Release the button when the motor unit lights blink If bulbs are not installed you will hear two clicks. I hope this fixes your problem - please post & let me know - thanks Sam
1. Press and release the learn button on the motor. The learn
2. Within 30 seconds enter a four digit personal ID number of your
3. Release the button when the motor unit lights blink If bulbs are not
That's funny, I have the same problem exactly (just bought a new place today) ... although I didnt find
out the model number so it might be slightly different. Anyway I'm
going to try this:
https://answers.google.com/answers/threadview?id=452310
tomorrow and see if it works ... good luck
SOURCE: sears keyless pad
I am not sure how to upload a file on here but I have the instructions for programming the key pad. if you would like a copy let me know!!
Here is a link from sears but you have to register your e-mail address to view it - no major thing!
Hope this helps!
http://www.managemyhome.com/mmh/products/ManualSearch.action?sid=MMHMxSearsx00019&product.modelNumber=13953684&product.brandName=CRAFTSMAN
SOURCE: How to reprogram Sears Mult-Function Keyless Entry garage opener
hit learn button for 2 seconds, enter 4 digit code on keypad and hit enter. light bulb blinks 2x. for remote, hit same learna and hit remote button.
SOURCE: I want to re-program my keyless garage door.
Mulleta,
If you look on the back or side of the garage door opener you will see a small square red/orange button.
Push the button one time, and you will see an amber LED come on. Go to your keypad enter a four digit (of your choice) then press and hold the the enter button until the garage door opener light flashes and you hear a clicking sound. You can release the enter button and it will be reprogramed.
We have a Craftsman 132B21712 keypad for the garage door. It's worked for years on both garage doors (separate numbers for each garage door). All of a sudden the one side will open but the other code won't work anymore. The battery has been replaced. When I try to reset the code, the lights don't flash like they're supposed to. Help??
I do not have the instruction booklet to explain how to reprogram the keyless pad. My 92 year old father accidentally voided the code. Where can I get one or can you explain how to do it. thanks
I just moved into a condo with keyless entry 139.53876 and cannot figure out how to change the access code. Can anyone help me. Thanks.
L.
