Based on the symptoms you are describing, it sounds like your dryer possibly has a faulty motor or an item is jammed in the blower wheel. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause. You can often locate a qualified service provider through the manufacturer website.
Good Afternoon John, let's try reprogramming the dryer by
either unplugging it or flipping the household circuit breaker to the off
position. It is important to wait approximately ten minutes and then unit the
dryer back on. If it proves to be ineffective, then the dryer may possibly be
experiencing more serious issues such as; a potential wiring failure, faulty
control board, thermal limiter, or defective door switch. Because it could be a number of any one of several
underlying causes, I would recommend contacting a professional to properly
diagnose and repair the unit.
Pull out lint filter and with the aid of a brush gently clean inside of the cavity where your lint filter fits into. There is a little sensor in there which once it gets clogged it will register that message. Ash
E50 code is for a motor issue or main PCB fault on the motor output
side (also called E51 when the triac that is on the main control board normally shorts out due to a faulty motor).
Not easy to diagnose as a diy job, but you need to find out if the
drum rotates correctly when fully loaded. Could check this CODE LIST
If you are having problems with your
gas dryer not heating the most common problem is that the ignitor
goes bad. Even though it glows sometimes it is still not working
properly.
if
you dryer is gas check out this gas
no heat
tip....
If you have an electric dryer, you can
have many different things that can go wrong causing the dryer not to
heat.
Check the dryer dual breakers in your house electrical panel--push off, then on. Try the dryer again. If still no heat, measure the voltage at the dryer socket with a voltmeter across the two slanted slots. It should read ~220 volts AC if correct. If zero, one of the breakers is bad or there is a loose wire between the breaker and the dryer socket. If you read the required voltage, then the problem is within the dryer--likely the heating element. The drum must be removed to access the element.
