At the end of the last spin cycle, the tub makes a clicking type noise until the basket stops spinning. The drive block was replaced last week. Any thoughts?
Greendude...thanks for the advice. I used a hammer and a spanner wrench on the nut to make sure it was tight enough and sure enough, that worked! Thanks again.Greendude...thanks for the advice. I used a hammer and a spanner wrench on the nut to make sure it was tight enough and sure enough, that worked! Thanks again.
It sounds like the drive block may be stripped out. To check it, you will need to remove the agitator to see if it is bad. Below is a video to show you how to access the drive block. Here is the part to order if you should find it bad.
If the drive block is good, post back to me and we will continue the diagnostics on the unit.
Thanks for using FixYa. If your washer is a front load washer then check these things if it is making noise--
Bellows
The
bellows is a rubber sleeve that seals the suspended outer tub to the stationary
cabinet front at the tub opening. Its purpose is to provide a water tight
opening into the tub that can be sealed by the cabinet door, yet allow
flexibility for the oscillation of the tub during the wash and spin cycles. Outer
Tub Assembly
The
outer tub assembly is supported by two suspension springs and stabilized by two
air shock assemblies. A cement counter weight is mounted to the front of the
outer tub by screws. A counterweight is molded into the rear half of the outer
tub. These counterweights prevent excessive oscillation of the entire suspended
assembly during an unbalanced spin cycle. Spin
Basket Assembly
The
spin basket is constructed of stainless steel. The circumference of the basket
is perforated to allow water to flow through it as it revolves. A heavy steel
shaft is pressed into the spin basket support which is then bolted to the
basket. The spin basket assembly is entirely supported by two ball bearings
pressed into the rear of the outer tub. A large drive pulley is mounted to the
free end of the shaft that extends through the rear of the outer tub. There are
three plastic vanes mounted to the spin basket to aid in the washing action
during the wash cycle. The rotation of the spin basket provides both the
washing action during the wash cycle, and water extraction during the spin
cycle.
High pitch "jet engine" noise--A certain
amount of motor whine is normal during the spin cycle.
Rattling and clanking noise--
• Foreign objects such as coins or safety pins may be in
drum or pump. Stop washer and check drum. If noise continues after washer is
restarted, objects may be in pump.
• Belt buckles and metal fasteners are hitting wash drum. To
prevent unnecessary noise and damage to drum, fasten fasteners and turn items
inside out.
Squealing sound or hot rubber odor-- Washer is
overloaded. Do not overload washer. Stop washer and reduce load.
Thumping sound— Heavy wash loads may produce a
thumping sound. This is usually normal. If sound continues, washer is probably
out of balance. Stop washer and redistribute wash load.
Vibrating noise--
• Washer is not resting firmly on floor. Move washer so it
rests firmly on floor. Adjust leveling legs. NOTE: Some shaking of the washer
is normal without moving across the floor. See INSTALLATION INSTRUCTIONS for
details.
• Shipping bolts and foam blocks have not been removed
during installation. See INSTALLATION INSTRUCTIONS for removing shipping bolts
and foam blocks.
• Wash load unevenly distributed in drum. Stop washer and
rearrange wash load.
Please do rate the solution and revert for further assistance.
It could be a couple of things. Either the basket drive block has worn or come loose and the spin tub from the basket drive is "clunking" as it skips by the notches in the block, or the basket drive spin tub has broke from the hub/base. It is likely the prior not the later.
Pull the agitator and inspect the block/hub in the center directly below the agitator which holds the basket in place. if it looks worn or is out of place, you'll likely need a tech.
If you can tackle it yourself, the block number is #389140. You want to be sure the spin tube still has the two notches in it though, otherwise the changing of the block will be futile.
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further. Good luck!
its your basket drive or sometimes called brake spin tube also comes with new clutch, ,transmissions wouldn't make that noise in only beginning of spin. your on your way to being a repair tech good job
Hi pils, As before I am not sure how your machine is built, but what you describe sounds like a problem with either the basket drive block or the brake system. The basket is going to be mounted to the spin tube with some sort of aluminum adaptor and a nut, at least that's how most all our machines are made. Sometimes the drive block becomes unseated from the drive tube coming up from under the machine and will make a lot of noise when the brake applies at the end of the cycle. This is usually accompanied by the water not being spun out of the clothes as well as it should. It may be the brake "jumping" when it applies to stop the basket. What ever it is, it has something to do with the load being reversed when the spin stops. When the machine is spinning, the torque from the motor is transferred through the drive mechanism to turn the basket. When the motor shuts off, this torque is reversed as the momentum of the weight of the spinning load of clothes becomes the driving force and it is transferred back down through the machine until it stops. Try turning the basket by hand in the direction of the spin and see if you can recreate the noise at at a slow enough speed to be able to pinpoint where it is coming from. mike
The most common cause of the symptom you are describing is a bad drive block which has probably ruined your basket drive as well. Let me give a quick explination. The weight of the basket you put your clothes in is supported entirely in the center of the washer underneath your agitator. It rests on an aluminum block called your drive block. So that the basket will move back and forth while the washer agitates, there are two tabs on the drive block that lock your basket drive underneath in place. Once the drive block wears out or round down these tabs, the basket will raise slightly and "skip" across the top when the spin cyle is stopped. To verify this, you can check one of two things. First (and easiest) is put a heavy, large load in the washer, get it wet then spin it out. Once the washer reaches the maximum spin speed, open the lid. The washer should snap to a halt when functioning properly. What I belive you'll find is that even with the lid open, the basket will continue to spin. The other method to verify this is take the top of the agitator off. Next remove the bolt in the middle of the agitator and lift the agitator off. In the middle, you should find a large flat metal colored nut.In the middle of that nut, you should see two tabs across from one another. There should be two straight pieces of metal coming up from the bottom which have nice, straight sharp corners. Again, if I am correct, you will find they have been rounded off and there may even be shavings of metal visable.
To replace a basket drive and drive block, you will need to purchase the parts and also a specialty tool from removal and instalation. These will probably run you around 125-175. If you are interested in giving it a go, reply back to me and I will get you some step-by-stpe instructions typed up.
The basket drive and the drive block will need replacing. The nut that holds the basket to the drive block may have come loose causing the drive block to 'jump' over and damage the tabs on the basket drive that causes the thumping as the spin cycle ends. To repair, you will need to purchase a basket drive and drive block. The agitator, balance ring, basket and transmission, will have to be removed in order to replace the basket drive. If less than 3ys old, consider contacting whirlpool for possible warranty concession.
Sounds like the drive block is defective. The drive bloce is a aluminum part that attaches the drun to the gearcase. If you remove the agitator you will see a large nut on top of the basket. If the drive block is worn yo will see aluminum peices on top. It is very simle to relace. You will need a spanner wrench to remove the nut. With the nut removed lift the spin basket up and out. Remove the block. You will see that the new block will only fit on one way. Tap it down untill it will not go any further, replace the basket, make sure you tighten the nut securly replace the agitator and you will be back washing.
What did you do?
