Fan runs but doesn't remove moisture
There are many reasons for a dehumidifier to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
SOURCE: Unit will run but will not kick in to remove moisture
the compressor sounds like is not coming on check the refrigerant or check the power to the compressor it could be something as small as a humidistat which will not tell it that we still have humidity like a thermostat
SOURCE: The unit turns out and runs fine. The fan blows.
You may have the humidity level set to high. If it's above 60%, that's what it's going to maintain, not remove. Set the humidity level on the lowest setting and try again. Whether you're using the hose or not, I don't suspect it's playing a role in it. Also, clean and reinstall the air intake filter.
Hope this helped you solve the problem. Please let me know. Thanks.
