Sony KP-51WS500 51" Rear Projection Television Logo
Anonymous Posted on Apr 02, 2008
Timer Standby light flashing No pitcher
No picture we timer standby light flashes
  • 1 more comment
  • itswinniechu Jul 13, 2008
    the same thing happen to me. i tried unplugging it for one day to see if it will turn on the next day but it didnt. but the TIMER/STAND BY light wont stop flashing. how can i fix this?
  • gregvoss May 09, 2009
    Sony Trinitron: power on set and standby / timer lo
    ight blinks continuously - audo, but no video
  • rdburt May 18, 2009
    timer light flashes and tv won't stay on.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 21, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1673
Points
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
A
Anonymous
How can you fix the blue crt and where can i fine it. Sony KP-51ws500
Anonymous
Level 1:
  • Posted on Mar 02, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1673
Points
Timer stand by light blinking 7 times tv won't stay on
Standby/timer light stays on red. no picture or sound on tv.
this is a simple capacitor fix at your local tv guy..should be 100 to $150 max
Standby/timer flashes and screen goes black
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
3helpful
Hlp 5063w on off front button flashing lamp then stanby..hear sound no picture.. shuts off then comes on.
If the lamp and standby lights are both flashing and the timer light is off, check that the lamp cover on the back of the TV is properly positioned in the groove and secured by the screw. Take it off and check that the screws that hold the lamp itself are secure. There is an safety feature that keeps the lamp from turning on when the lamp cover is off.
If the three lights (timer, lamp, and standby) are blinking, then the lamp needs to be replaced. If the timer and standby lights are blinking and the lamp light is off, then a cooling fan isn't working. When only the standby light is blinking and the other lights are off, the unit is overheating and a ventilation area may be blocked.
I hope this helps.
2answers
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Red light flash timer stand by
Please count standby light blinks and let me know.
There would be pause of 3 seconds in blinks.
Also confirm is it Sony KP-57HW40 model?
8helpful
my sony red light flash.but it will not turn on just clicks
2helpful
2answers
Power comes on, red light flashes on timer/standby but no picture
Need the model number of your set and also how many times is the led blinking? Please respond to this same post
The standby timer light is flashing
broken surface mount resistor of main power supply
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
