terminals. Internally in the amp the positives (1 and 2) are connected together and negatives (3 and 4) together. So there is no difference between hooking up in any of the configurations 13, 14, 23 or 2->4. If its a matter of style, probably use the 14 set, since they're furter apart and harder to short out that way, but electrically it doesn't matter.
Be sure the RCA cables are attached and in good condition.
Be sure the remote wire from the deck is hooked up and good.
Be sure the GAIN control is turned up.
Volume on head unit is up. Make sure BASS options are not turned off on deck.
Be sure wires are going the right way. + to + & - to -
Loose wires in the box. Make sure subs are hooked to the terminals inside box.
Check all fuses on amp to determine if 1 or more i blown.
You should check and verify first the output signal in the amplifiers by using a multimeter on the db range, this is to identify good output of the amp. After that check the polarities for correct wire orientations.You should connect the speakers one at a time to check.
make sure that the connected speakers have the correct impedance. should be 4 ohm typically. some amps support 2 and 1 ohm, too. wrong impedance could occur when you connect two speakers in a row for example. it's all about electric law.
This feature allows the amp to be paired to any stereo. The input may be in stereo but the amp then changes it back into mono using sound from both sides. Hope this answers your question.
ok i have the same amp and 1 2ohm dvc sub and was woundering the same thing but from futher research and askin sum xsperts. What i found out is that it is only one channel and even tho there are 2 (+) and 2(-) they actually connect inside the amp makein it one . so if u wanted to wire sumthing parralel u wouldnt have to hook wires from one coil to the other on the speaker , u can just hook it up to the amp. so basically both +'s and negatives on the amp are actually one within it so all the power if you only use one set of them and if u wanna add more subs its just easier to add to the amp by using the xtras .
