SOURCE: driver update problem for digital camera
In order to get rid of the error, you have uninstall the driver, update your operating system with updates from Microsoft (see below for instructions) and follow these suggestions:
This information is in the manual on page 96. See this link for the manual.
See this link for details about the WIA driver.
About the error "driver update failed" rea
I personally have stopped altogether trying to get the drivers and software installed because they can cause more problems. I just transfer using a card reader.
If you want to use the software that comes with the A400, it's best to install ZoomBrowser, then you will need to follow to this link to get the update to this software.
Once this is done, reboot your machine to make sure the system is then up-to-date.
Make sure you have also updated your machine with Windows Updates. This is done by opening Internet Explorer and clicking on Tools | Windows Updates. Follow the links at their site to update your machine.
SOURCE: Aries driver
http://www.filefactory.com/file/af617b7/n/Aries_Camera_iso
Ignore the mewling about joining, scroll down to the bottom of the page and choose "Basic" download. 207 MB, be patient.
Burn .iso, unplug camera, mount CD, choose "Install Driver", reboot when done, plug in camera.
Don;t lose this, there are no copies on the web
SOURCE: OLYMPUS Master.exe has encountered a problem and needs to close
1. identify wich copy of mfc80u.dll in the WinSxS your Oly Master is using. I did this renaming one by one and running the Master 2 to see if it continue to run or not.
2. Once identified the folde (mine was C:\WINDOWS\WinSxS\x86_Microsoft.VC80.MFC_1fc8b3b9a1e18e3b_8.0.50727.922_x-ww_3cf1180b), copy the mfc80u.dll from the OLYMPUS Master 2 folder to the corresponding WinSxS folder
3. The Master 2 should run fine now
SOURCE: have a new sony dsc-w120
OK,
Camera has small inbuilt memory that can store few pictures. You can copy these photos in memory stick by inserting memory stick in camera, go to Menu >> Copy >> Yes.
Memory stick stores many photos depends on its size and let memory stick in camera, hook it with computer and transfer photos from memory card.
Thanks.
SOURCE: I have a Fuji FinePix A340 digital camera (c. 6
Bought a 1GB card (XD) for mine at a local drugstore and it works just fine after updating the firmware. Had trouble with the online stuff, so took it to Fuji in Missauga, Ontario (almost next door for me) for updating. Cost was $15.
Testimonial: "Thanks so much for the help!"
