Garden Logo
A
Anonymous Posted on May 17, 2010
Craftsman lawntractor (1994) model: 917.257720. Using igniton switch will not start tractor. Turning ignition switch to on position and using screw driver from relay to starter by cross connecting post on relay does start mower. Mower will shut off using ignition off position. Question: does this indicated bad ignition switch?
Ron Fredey
Level 1:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Aug 17, 2012
Ron Fredey
Contributor
Level 1:
Problem Solver:
Answers
10
Questions
5
Helped
42435
Points
27
Replace your solenoid.
4 Related Answers
Anonymous
  • 49 Answers
  • Posted on Feb 11, 2009
SOURCE: craftsman mower 917 273201
Check the seat switch for the running problem. Disconnect the switch and jump the harness with a piece of wire, and see if the tractor stays running. If so, then the switch is bad. As for the charging problem. Test the voltage regulator. Start the tractor and put a volt meter across the battery. Red to red and black to black. Run the RPM to full throttle. You should have a reading of 14 to 14.5 volts. If not, the regulator is bad. Hope this helps.
Anonymous
  • 6 Answers
  • Posted on Apr 06, 2009
SOURCE: how to install mower deck belt on a lt1000 craftsman riding mower
The manual will cover it.
http://www.disruptit.com/manuals/L0104168.pdf
Anonymous
  • 13 Answers
  • Posted on Apr 16, 2010
SOURCE: nothing happens when you turn on the lawn mower
Check your seat, drive safety switches. Can you turn the engine with jumper cables attached to the starter? It won't start, but should turn over, one of your safety switches is not working.
saailer
David Burbee
  • 1871 Answers
  • Posted on Jul 08, 2010
SOURCE: craftsman riding mower-what year was it made
Hello! The 917= American Yard Products...A major supplier to Sears...The first six digits of the SN#...00/00/00= date of manufacture...In your case...May,1,1997...
Guru.....................Saailer
Iā€™m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Testimonial: "Thank you very much!"
1helpful
Craftsman 21 hp lawntractor model 917.289240 will no go in reverse.
If this is a hydro unit and it runs ok forward there should be no other reason other than linkage adjustment for it not to run in reverse, for safety reasons they are normally adjusted to run slower in reverse
Craftsman Lawntractor 917.273811
if its a briggs motor .004 intake and exhaust cold setting
Apr 14, 2012 • Garden
How do I replace the ignition switch on a Craftsman Lawn Tractor?
There is a plug that plugs right into the ignition, just unplug it and unscrew the igniton.
Trying to replace broken brake rod
Go to www.searspartsdirect.com. Put in your model number there, it will come up with parts list and diagram for your mower.
Craftsman lawntractor model # 917273121
There is no tension adjustment it has an idler pulley working off from a spring. Check to make sure that the spring did not come off or break. If neither of these have happened then the belt is stretched and you need to purchase a new one.
1helpful
Craftsman 19.5 42 lawntractor, steering started clicking, then would nto turn wheel. Bar underneath unattached hitting ground. Do not know where it goes. How can I fix.
not a expert just trying to help,,sounds like you have two or mor problems,, first the bar will only go to one side of the front wheels,if it does not snap into place,you will have to replace the joint.,, the clicking sound maybe the steering unit sliping,,look down from steering wheel follow the shaft down to the steering gears,, they might be worn out.. hope this help you
Clicking noise
removed engine cover - found starter was hung up, this seems to have fixed the problem it starts and runs fine now.
Lawntractor does not move forward or backward
you might check the pulleys to see if shear pin has broken.
Putting all belts on
look at the guard for the blades, the diagram routing is drawn there , u may have to loose a nut or 2 to get ot out of the drive pulley
Top Garden Experts
Jay Finke
Jay Finke
john h
