ITU is missing or defective. Try reinstalling the ITU. If this doesn't work you'll have to replace it. The ITU is the black "belt" at the bottom of the printer.
Perhaps this article on 900 Errors on a Lexmark C752, C760, or C762 will help. Just click on this link: http://bit.ly/c2xr1t. There are embedded links on the page for additional info. If you need further assistance, don't hesitate to contact Lexmark technical support or your authorized service provider.
lexmark basically has said that if this error doesnt clear by powering off the machine and powering it back on again then it will need to have a service call. this error means there is a problem with the itu belt assembly.below is what they say. the steps were to pwoer it off and back on again using a grounded wall socket
This error normally requires a service call. However, certain rare occurrences, such as a stray static discharge in the vicinity of the printer or a power fluctuation, can cause a false 103 ITU error message to appear. In these cases, the error is only temporary and can be easily resolved without service. Follow the steps in the table. StepAction1 Power the printer off, wait ten seconds, and then power the printer back on. Did the error message return?
Yes: Continue to step 2 No: Print a test page. If the page prints, the printer is functioning correctly.
2 If possible, connect the printer's power cord directly into a grounded wall outlet. In rare instances, a surge protector or uninterruptible power supply (UPS) can generate false error messages. Did the error message return?
Yes: Continue to Contacting Lexmark below. No: Print a test page. If the page prints, the printer is functioning correctly.
r u using refill toner than spill over will happen
use good quality toner
plus clearn the ITU drum regularly
if using genuine toner than demand replacement fm lexmark for this problem
