I lost the manuel to my GSD4930X66WW and it keeps saying C1 and C2...I need to know what to clean...I need a owners manuel and I think I would be able to fix it...
Hey Hugo, found this info. purple wire. I hope you don't need help with all 38 wires? autozone.com has free wiring diagrams, just register your vehicle and click on vehicle repair guides, find the link for wiring.
C1 is blue connector, c2 is black connector
c1-35 goes to brake switch
c2-61 goes to vss, vehicle speed sensor
c1-59 goes to datalink connector
c2-22 goes to pre converter 02 sensor
Formulas don't usually contain data, but display some transformation of data held in cells that do contain the data.
ie cell C3 may have a formula that says "=C1-C2"
Which means that C3 will display the result of the operation of subtracting the content of C2 from the value held in C1"
Clear out only the cells that contain the source values (C1 & C2) and your formula (C3) will remain.
For the first part, the problem doesn't change if rearranged to say "A cat is let out of the bag and bites you. While you're noticing that the cat is white, another cat escapes the bag and runs up the tree. What's the probability that the second cat is white?" For the second part, what are A and B? How do they apply to the problem?
Use unlock code to unlock your Nokia C2-01. Get the code from the site Wickedunlock.com ,and unlock it using unlocking instructions which is given in the site itself.
The c1, c2, & c3 are for exchange rates. To set the c2 exchange rate press AC. Press the MODE M/EX button till EXCH appears in the display. Press and hold the SET/% button for a few seconds until SET EXCH appears in the screen. Press c2, C2 SET EXCH RATE should be displayed. Enter the desired echange rate. For instance, today, Thai Baht is 32.8677. Once you enter your desired exchange rate, press the SET/% button.
To convert 100 dollars using the exchange rate you set on c2, make sure that EXCH is in the display by toggling the MODE M/EX button. Press AC, enter 100, press c1 then c2. Using 32.8677 as the exchange rate 100 dollars would be 3286.77 THB.
To convert 100 THB to dollars you would enter 100, then press c2 and then c1 yeilding 3.04 dollars.
You can also program a different exchange rate into the C3 button. To convert to that currency, you press c1 then c3. To convert from that currency, you press c3 then c1.
When you press the [M/EX] key, it toggles between conversion mode and memory mode. You will see "EXCH" on the display when in conversion mode. C1, C2, and C3 are three conversion rates. C1 is your home country currency, and so it is always set to 1. C2 and C3 are rates for two other countries, which you can change. For example, if you want to set a conversion rate of $1 to 0.95 euros, here is what you would do (using C1 for US dollars and C2 for euros): 1. Press [AC] 2. Hold [SET/%] for about two seconds until "SET" appears 3. Press [C2] to select currency 2 4. Input the conversion rate (0.95) and then press [SET/%] to store it in memory You can check the currently set rate at any time by pressing [AC] and then [C2].
How do I perform a currency conversion?
If you want to convert 100 euros to US dollars, you would do the following (assuming you are using C1 for US dollars and C2 for euros): 1. Press [AC] 2. Enter 100 and then press [C2] 3. Press [C1] to convert to dollars 4. To convert back to euros again, press [C2] You can also perform a currency conversion within a calculation. How much in US dollars would five items selling at 100 euros cost? 1. Press [AC] 2. Enter 5 [×] 100 and then press [C2] 3. Press [C1] [=]
