Message "F21" flashes on the time remaining scree. I'm unable to unlock the washer's door and/or power it off without unplugging it. Once plugged back in, the red light/door lock is still on - and can't open the washer.
Lets see: F21 Long drain Possible cause: Clogged filter, clogged/failed pump Remove the botF21 flashes on the time screen -- am unable to pow - 299686f.jpgmg src="/uploads/images/299686f.jpg" alt="299686f.jpgF21 flashes on the time screen -- am unable to pow - b1cfae3.jpgmi" /> go for the pump cleanout, get the googus out. Tech sheet is located behind the white box to the left which is the motor contrF21 flashes on the time screen -- am unable to pow - 7b78889.jpgU). The tech sheet is an excellent tool which gives directions on diagnosing those pesky fault code. LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Hi
F21 error means that the drain time has exceeded 8
minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to
clear the display. If errors still remains then please check the drain hose and
make sure it is not plugged or kinked. Disassemble the washer by removing the
back from the washer and check the electrical connections at the pump and make
sure the pump is draining. Also inspect the pump filter for foreign objects.
Before disassembling remember to turn off the power and disconnect the washer.
If it still doesn't help then there is an issue with the pump and you'll need
to replace it. Hope this helps... Please post back if you need more
information.
Daniel
Hi
information.
Daniel
Hi
information.
Daniel
To Manually unlock the door lock system:
1. Unplug the power cord from the outlet.
2. Remove the lower toe panel.
3. Reach up along the inside of the front panel and locate the bottom of the door latch assembly.
4. Located on the bottom of the door latch assembly is a tear-drop shaped tab.
5. Gently pull the tab down about ¼" or until a click is heard.
6. The door may now be opened.
Hello &
Welcome to FixYa
F21 error is displayed when the washer is unable
to drain, press PAUSE/CANCEL button twice to clear the display. After this
please check the drain hose and drain pump filter for any blockages and make
sure it is not clogged with foreign particles. You can also check the drain
pump to verify that its working. Please get back to me if you have any other
questions.
Kevin
Hi
F21 error means that the drain time has exceeded 8 minutes; this will turn off the water valves. Press PAUSE/CANCEL two times to clear the display. If errors still remains then please check the drain hose and make sure it is not plugged or kinked. Disassemble the washer by removing the back from the washer and check the electrical connections at the pump and make sure the pump is draining. Also inspect the pump filter for foreign objects. Before disassembling remember to turn off the power and disconnect the washer. If it still doesn't help then there is an issue with the pump and you'll need to replace it.
Hope this helps... Please post back if you need more information.
Daniel
