SOURCE: bosch wvt 1260
dry heater is located under an aluminium housing on top of the machine. take it to bits and easy to fit. however, why do you need a heater? if no heat on dry, cause is probably overheat stat operated
SOURCE: Want to buy a new
Sorry. As we are scattered all over the world it would be difficult for anyone on the forum to tell people where their 'local' suppliers are, even if we knew where they were ;-0)
Spares Suppliers
You will need to type into your search engine/web browser '(make) washer spares' and you should be presented with a number of sources from which you can order. During the process you will be asked for the actual model number.
Alternately you could try telephone directories for spares suppliers but I would think the former would be more successful.
Good luck,
John C.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
