Nordic Track /proform Treadmill Drive/motor Belt 118016 Logo
A
Anonymous Posted on May 16, 2010
Belt stop working. All lights lit.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 12, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1277
Points
HAPPILY WALKING ALONG AN THE MOTOR JUST STOPPED. aLL OTHER CONTROLS STILL WORK. jUST THE BELT AND MOTOT WON'T FUNCTION.
iS THERE A PART ON THE POWER SUPPLY THAT HAS BURNED OUT?
2003 ford escape seat belt warnign light
Probably no need to see an expensive mechanic. My seat belt warning light came on a few days ago when there were four people in the car and the rear seat belts weren't fastened (I thought that was why it lit up). However, the light came on and stayed on when I was the only person in the car. Logically, it suggested a bad connection somewhere, so I checked the connector under the passenger seat and made sure it was properly fastened together. I then sprayed a small amount of WD40 into the female clasps of both front seat belt connectors, clipped and unclipped the belts a few times and the light is now fine. Try it - it worked for my 2003 Escape.
My power steering pump is not working would that cause my battery and oil light to light up on my dash board
You haven't removed power steering belt right? The power steering belt it's the same for the alternator and the oil pump, if that belt is burst then you are gonna have your battery light lit and your oil pump won't work so it's gona detect low oil pressure and your oil light will lit too. Make sure that you don't have a missing belt, cause if you do and you keep runnig the car, the battery will discharge and the engine will be damaged. If the belt is ok, if the power steering is getting stucked then the belt may be getting stucked too and that's gonna cause the same troubles. If that's happening it's gonna continue doing it until the belt cracks or the power steering pulley blows.
Dryer stopped working will not turn on was working fine we have power to the outlet is there a thermal fuse to replace
Some have a stop switch on the belt tensioner. If the belt breaks the switch prevents the drier from turning on. Door swich can also cause dryer not to run. Do you see any lights on? Is there any LED's lit up on the display?
1helpful
91 honda ex, passenger front seat belt is not working and the light in the dash board keeps lit, I have check the fuses for it, and all the connection to the belt and it seems all intact...any advise?
Your 1991 model Accord has automatic front retracting shoulder belts and, more than likely, the power retractor motor has gone bad on the passenger side front. If the shoulder seat belt is not in the retracted position, up close against the seat, when the car is running, the seat belt light will stay lit on your dash. Have the seat belt motor inspected and replaced if necessary.
Hi, is there a way to stop the OKI 3200n printer from demanding a new belt, the printer is working just fine but the darn red light stays lit
It will continue to report this until replacement. In my experience, it won't lock you out, but the error is a result of the printer testing the integrity of the belt, so until it is replaced, it will report this error. Use it until yu see print issues, and then replace.
I have the check engine light battery light and power steering doesnt work, but all fluids are nominal battery is producing correct voltage
check your drive belt, this si the belt at the front of the engine. Make sure its secured and not loose. with the powersteering not working and the battery light lit may idicate a faulty serpentine belt (drive belt). If this is ok, please post additional info..hopefully this helps!!
3helpful
Miele g892 and just like everyone the red light comes on and dishwasher stops running> why cant you answer thic common problem>
The red light tell you there is a fault. You have to read the fault code and it will give you a general idea of the problem - to do this you have to enter the service mode of operation - close the door and turn the dishwasher on.
The Start/Stop light must be blinking. If the Start/Stop light is not blinking, press and hold
the Start/Stop button for at least 3 seconds to exit the cycle. The Start/Stop light should now be blinking.
Press and hold the Start/Stop button while turning the dishwasher on. Release the
Start/Stop button and immediately press it 2 more times. Flashing Intake/Drain and
Salt lamps and a lit Rinse lamp indicates successful accessing of services mode
Fault codes
F00 Pots & Pans Lit
F01 Sani Wash Lit
F02 Normal Plus Lit
F03 Normal Lit
F04 Economy Lit
F05 Rinse & Hold Lit
F06 Pots & Pans Lit
F07 Sani Wash Lit
F08 Normal Plus Lit
F09 Normal Lit Flashing
WRT54GS router stopped working
try holding down the reset button which should be behind or under the router for 30 seconds, still holding down the reset button turn the power off for 30 seconds, still hoding the reset button wait more 30 seconds. After that your router should be in the way it came.
Was printing ok, then the printer stopped and the two KY & MC icons are lit up alongside the lit up 'paper' icon. I have changed 3 cartridges just now and the lights still come up and the printer stops....
Is the print head moving at all?
Turn power off and see if you can gently move the printhead carriage or turn the carriage belt pulley on the left. If it moves freely without the carriage moving. Thats your problem.
There is a rubber mounted belt connector under the printhead carriage that often breaks when the slide is too dry from lack of lubrication.
I called hp to get the part. No part available. so I repaired the part with epoxy. Not an easy fix.
Top Nordic Track Exercise & Fitness Experts
ZJ Limited
ZJ Limited
vince
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
