This freezer has a thermostat that adjusts the coldness of this fridge marked on different ranges from lower to highest, if digital it's adjusted according to coldness you need your consumables to be. so try to adjust it to colder values or it mayn't be faulty not responding either not switching on compressor, this is why it warms up or switches on the compressor with out switching it off for a long time.
It also has a defrost timer that may need to be checked,even the compressor should be checked to
see weather it's working perfectly,plus the compressor relay this is attacked to the compressor
it could be tripping due a malfunctioning.
Contact a service engineer let him/her visit the mentioned areas.
Hope it works for you.
Thank you for your post friend.
I understand that you are having intermittent defrost issues with your Frigidaire refrigerator. Are you experiencing an accumulation of ice buildup, are you losing food? Defrost issues can be caused by a variety of things such as a defective defrost heater, thermostat or defective door gasket. I recommend that you visually inspect the door gasket for defects such as gaps or tears. You can also use a dollar bill to test the door gasket. Place a dollar bill in between the door and the body of the freezer. If the dollar bill pulls out with no to little resistance, you may need to replace the door gasket. A faulty door gasket can allow warm air to enter the compartment and cause frost to buildup.
If there is a miscommunication within your freezer, a reset can possibly correct this issue. I recommend that you reset your refrigerator by unplugging it for 10 minutes. I hope this information has been helpful. -NS
