The door latch (part #9902839) split and I need to replace it. The door still opens and closes properly if I grab the latch from the rear, so it is a cosmetic problem, hence not covered under by extended service warranty. I can buy the part for under $20 but don't want to have to pay for a service call to replace the latch if I can easily do it myself. Unfortunately, Jenn-Air doesn't provide tech support. Does anybody know if this is easily fixable, and how do do the repair?
SOURCE: Second repair on F9-1 Error Code
stove computer needs to be re-set. as given in already posted solutions. But i will add ....keep trying . It took 7 trys but finally the darn thing reset itself. Ps I shut off power for a good 5 minutes before trying the reset procedure. also I did not hit the final cancel ( last step)
SOURCE: door spring on dishwasher broke
I have just done this on my own dishwasher, and managed to bend the next curl of the springs to replace the broken ends, see instructions and pictures here:-
http://www.howtofixanything.co.uk/howto-260.html
SOURCE: jenn air cook top
Yes you can. Call Jenn Air ((877) 232-6771) and give them your model number (serial is helpful too). They sent my replacement glass within a week. I have a model JED8430ABD from 2000 and they had the top. Fit perfectly and took about an hour to replace.
To change it out, after unplugging the cooktop, I removed the metal tape connecting the external vent shaft to the blower. Then I just lifted the entire cooktop out up out of the countertop so I could access the screws on the sides of the cooktop (looking at the edges of the new cooktop glass helped me figure out which screws to remove around the edge). Then I removed the 2 screws in the vent area on top (1 black screw on each side). And that released the cooktop glass from the metal box that holds the burners. I then took the rubber rings out of the knob holes so I could put them in the new cooktop (I almost missed that...). Finally, I put the new cooktop glass on, put the screws back in, lowered the cooktop back into the counter, and retaped the blower to the vent shaft. Voila!
I really wouldn't be afraid of doing this yourself if you are handy at all. And it will save you a ton. Good luck.
PS The screws around the perimeter are hexigon shapped, so you can't just use a screwdriver. I found my Black & Decker electric screwdriver had that same shaped hole that it held the bit, so I just pulled out the bit and used the screwdriver that way. Worked like a charm.
SOURCE: Jenn Air dishwasher door won't close
It could be as simple as the mounting tabs being too tight up against the bottom of the countertop. You might need to loosen the 2 screws that hold the dishwasher in place against the underside of the countertop, until the latch and strike plate engage.
It might be that the countertop is interferring with the latch or that the door edge doesn't have enough clearance to properly close and engage the latching tab.
If you can't get the latch to engage, it might be that it got bent slightly in the removal and reinstallation. A simple way to confirm this would be to pull the dishwasher out about 4-6" from the cabinet and see if the catch and latching tab line up and engage. If they do, then you need to make sure there is enough clearance around the cabinet edges and at the underside of the countertop. If it doesn't engage, then it is more likely that the tab (male part) needs to be adjusted slightly to allow for proper engagement. Make small adjustments (bending carefully up or down until it goes into the latch without binding.
You should be able to get this lined up with a little effort and have things working again.
Hope you found this Very Helpful and best regards!
Testimonial: "The advice got the door moving better, but I appears that the latch is broken and will have to be replaced."
SOURCE: Our Jenn Air Quiet Series does show any power when
aside from the lights not illuminating does the wash cycle proceed?
Door catches.
One of the latches may be damaged or
misaligned and is not lifting the other latch clear of the housing.
Remove from any power source, remove the cover of the cabinet.
Slacken off the clamp mechanism and ease the clamp over the guide to
allow the door to open. When the door levers are in place, the door
may be easily adjusted by slackening off the screws that clamp the
door catch/actuators in place whilst holding the door closed and then
tightening the screws. The rear of the door may be adjusted by
slackening the lower door hinge screws and adjusting as required.
Door switches
If one of the door interlock switches
is not switching properly or there is a condensation problem on the
sensor control panel, either can cause the turntable/light/oven to
come on even though the "Start" button has not been
depressed due to the wiring of the switches.
Check for faulty door
switches and/or contaminated actuators.
I hope that helps.
