Samsung HL-S5086W 50" HDTV Logo
Posted on May 18, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
White dots appear on my screen - Samsung HL-S5086W 50" HDTV
Anonymous
Level 3:
President:
  • Master 3,130 Answers
  • Posted on May 18, 2010
Anonymous
Master
Level 3:
President:
Answers
3130
Questions
5
Helped
1649747
Points
8439
That sounds like a common effect that plasma sets develpe ehen the voltage on the screen driver is set out of spec, or the plasma screen assy is going bad, 90% of the times that I have adjusted the voltage the sparkling effect came back, indicating that the plasma display is going bad. or the power supply is going bad, most of the time dried out or bad capacitors in the main power supply in the set. I wish I would have written down those capacitors values and their numbers., as I remembered I found the bad caps because the tops were swollen a little bit. not yet bad yetr but on thier way their. and if left unchecked they will blow up and causing a lot more damage to the power supply
Techman
1helpful
2answers
Cracked screen & white dots appearing since the crack appeared
I have a Mitsubishi TV and had the same problem. There is a mirror that moves to control each pixel. When some of them fail to move you get the white dots. Google your problem and a company will come up(sorry forgot the name).,you can buy the new part from them and they have exact utube videos to help you do the repair. Took me about an hour. Part was around $150. Very rewarding feeling when you turn the tv back on with no white dots.Still dot free after two years
Lots of dots on the screen. In light areas they are black dots, in light areas they are dark dots
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.
we supply the new DMD chip,it's life is 6 years, and the price is USD200
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
White dots appear on screen
Sounds like your DLP chi is faulty
2helpful
I have nec np200 and there's a lot of dots appeared on the screen. what seems to be a problem
I have 2 NP-200 projectors installed in a school which show white dots on a black background and black dots on a white background. This is caused by the DMD chip losing pixels. Only solution is to replace the chip, I'm researching now if that i an economical solution.
Dots
white dots on screen
Many white dots appears on the screen of my benq w600 projector
Jacob, what element on the mainboard is the source of these dots? I have the same problem - it is only one dot now, but I think there will be more with time.
Also, the second question is: how do I unscrew the mainboard from benq W600+? I remoced the metal cover, unplugged all the cables, but there's something still not letting the board go.
White dot on my samsung DLP 42" screen
white dot is from a failure in the dlp chip. it controls 1000s of tiny mirrors which help make up your pix, when the mirrors get stuck a white dot appears. over time more will pop up. Probably in the $300-$500 range to have someone repair.
4helpful
White dots all of screen
sound like you have a bad dlp chip. this happens to a lot of samsung dlp tvs. some of the mirrors are stuck. they can appear as black dots or white dots and it usually gets worse over time.
1helpful
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
White dot has appeared on the screen and seems to be getting big
ok. unless your very good with electronics you need to call a repair man the colors got unalined.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
