Master
- Posted on May 17, 2010
Re: The lock will not release after cleaning
This is GE's trouble shooting advise:
Range - Oven Door Won't Unlock After Self Clean
The Oven Door has been Locked Accidentally:
- If no food or utensils are in oven, put it
into a short self-clean cycle (1-2 hours).
If there is food in the oven, let the oven cool
to room temperature and try to unlatch the door.
With electronic ranges there is a small
chance that turning the circuit
breaker off for a few minutes and turning it back on can release
the door.
latch to the "off"
Note: Do
not force the latch at anytime!
Door Will Not Unlock After Cleaning:
On models with mechanical latches:
- Once the oven is cool after a self-clean cycle
(approximately 30-90 minutes), slide the latch over to the left.(Some
older models have a latch release button that must be pushed in while
sliding the latch over.)
Note: Some models with
oven Set and Temperature
knobs must have those knobs set in the Clean position
before the latch can be moved to the left. If your door won't unlock,
try turning those knobs back to Clean, then
slide the latch over.
If the above suggestions do
not work try the following to unlock your door:
- Disconnect power to range for 30 seconds.
- Reconnect power and see if door will unlatch.
- If door does not unlatch, and you do
have food in the oven, wait for oven to cool completely and try again.
If it still will not open you will need service.
not have food in the oven, set the oven up to clean for 1-2
hours.
- Wait approximately 30 minutes and try to unlock the door.
- If the door unlocks, the control has reset itself and there
should not be any other problems.
- If the door will not unlock or if you would like to schedule
a service appointment, please contact GE Consumer Service at
1-800-432-2737 or schedule a service appointment
on-line.
Note: Under no
circumstances should you ever force the door or latch open.
