How to Format Nokia N72, N73, N81, N95, NSeries Mobile Phones.
Method 1: Three Finger Reset for Nokia Phone1. Switch off your Nokia phone.
2. Hold down the following three keys, Green (call answer button) * Key, and Number ‘3? key.
3. While holding these buttons, press the power button and switch on the phone.
4. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 2: Hard Format of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7370#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message ‘Formatting’ to appear on the screen and release all keys once you see that message.
Method 3: Soft Reset of Nokia Mobile Phone1. Switch off your Nokia phone
2. Now Press following key sequence *#7780#
Please Note: The Above Nokia Phone Formatting method will erase all your Phone data. So do backup before proceeding for Formatting
Nokia n85 8gb is easy to be formatted with nokia pc updater.
SOURCE: Nokia N95 8Gb
hi i will give you your master code but it wont work if you have entered the wrong number more than 5 times if you have then you need to purchase flash lead and unlocking software and equipment witch would cost more than a new phone.
This code only works with that imei number ok
your master code is 0246041706
Let me know if you need further assistance ok
Sorry its been a while but been away from home for few days ok
SOURCE: system error in nokia N95 8GB
take the phone to a mobile service shop and have them reflash the firmware on the phone for you.
SOURCE: Not showing full memory-China mobile N95 8GB
You can try to restore to factory default with *#7780# (you will not lose any data).
If it doesn't work, backup all your data first because you will lose all and do a soft reset with *#7370# (default pass is 12345).
As a last resort there is the hard-reset:
1) Make sure phone is fully charged and switched off.
2) Press simultaneously the green "call" button, "*" and "3" and keep them down.
3) With those 3 keys down, switch the phone on.
4) Release the 3 keys when the phone shows signs of life such as the Nokia logo or the language selection screen.
my Nokia phone N95 8GB i from china, i need to format ?
