man, hold the power and the home for 10 seconds then remove ur finger off the power and keep holding the home until u hear a sound on ur pc, now open itunes and restore ur iphone, before u click on restore hole the LEFT SHIFT and click with ur mouse on it, go to where u downloaded ur ipsw and restore, its very easy man :)) if u still having prob please tell me okkk
Your device was probably disabled because of entering an incorrect passcode several times, that's why even if you're trying to restore it over iTunes, it refuse to restore. That means the passcode lock is stil in effect. To bypass that lock, here's what you gotta do:
Plug/connect your device to a computer (PC or Mac)
Turn it OFF
Press and hold the POWER and HOME buttons together for EXACTLY 10seconds
Release the POWER button but keep holding the HOME button until the computer beeps indicating that a USB device is recognized.
Open iTunes and restore your device.
Warning: Restoring will delete all data on your device but this is the only way for you to recover it.
If you don't get it at first, try holding the buttons for lesser time or see the other procedures and some screenshots on my tip (link below):
For more iPhone / iPod touch tips like jailbreaking and unlocking, CLICK HERE or contact me personally at this email: [email protected] or add me on Skype: ebayseller.ca
trying to going in and doublue jump it or you may need to take all of them off the itunes and start over i keep 4 diiferent itouches and this has happened before so try that and see
unfortunately you will have to restore your ipod. Just connect it to your computer, and within itunes select the restore option on the ipod page.
The ipod should be able to be restored by the computer that last synced it.
Otherwise, try to restore your ipod via DFU mode. Here is a great step by step guide to do that. http://iphonefreakz.com/beginners-guide/howto-dfu-mode/
well you can conpleatly restore it by no luging it in and holding the power buton for 3 seconds then with out leting go of the power buton hold the home buton for 10 seconds then let go of the power buton and just hold the home buton for a further 30 seconds.....
after you have done this plug it in to your computer with iTunes allready running and a icon should say unresponcive ipod or somethin along those lines just click RESTORE
If your iPod is frozen or won't turn on, the steps to reset it vary by model.
Toggle the Hold switch. To do this, slide the switch to
Hold (an orange bar appears) and then slide it back (orange bar is
hidden).
Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
If
the Apple logo appears on the display, connect the iPod to a computer
and verify that it appears in iTunes and can play music. If the iPod
appears in iTunes and can play music, no further troubleshooting is
needed.
If the Apple logo does not appear or the iPod
is not seen in iTunes, connect the iPod to a power source by either
plugging it into an Apple iPod USB Power Adapter or directly into a
computer's USB port.
Let the iPod charge for at least 20 minutes. Note:
If the iPod is connected to a computer, make sure the computer does not
sleep, standby, or hibernate during the 20-minute charging period.
After
the iPod has charged for at least 20 minutes and while it is still
connected to the power source, toggle the Hold switch again as in step
1.
Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
If
needed.
If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
IF YOU HAVEN'T SYNCED IT TO ANYOTHER PC THEN SHUT OFF YOUR IPOD TOUCH CONNECT THE USB WIRE TO YOUR PC AND TO YOUR IPOD THEN HOLD THE POWER AND HOME BUTTON THEN ITUNES SHOULD GRAB IT.
The ipod should let you do a restore in itunes with the computer that last synced the ipod. This is the only way to remove the passcode.
If it wont simply show up on the computer, plug the ipod in, hold the power button and then slide
to power off. Press the power button, as soon as the apple logo appears
press and hold both the top power button and the home button together
until the orange triangle appears. This should put the iPhone into
restore mode, open itunes and restore.
