Computers & Internet Logo
A
Anonymous Posted on May 15, 2010
Emachine will not boot up. The fan and lights come on but thats it. In the recent past its taken several attempts to successfully boot. No new software or haedware added. The on button now will not turn the pc off. I tried the cmos battery reset with no results.
Anonymous
Level 3:
Guru:
  • Master 551 Answers
  • Posted on May 18, 2010
Anonymous
Master
Level 3:
Guru:
Answers
551
Questions
Helped
113661
Points
1166
Check the memory module and the processor. replace them if they are defective.
Emachine fans
upon turning on keep hitting f8 repeatedly to get to the bios menu and check your boot sequence
I'm the one with the emachine that won't boot just beeps resat RAM and repluged video.
check FAN on CPU. Check also the radiator on the CPU. If you can - remove CPU and check the paste between the CPU and radiator - apply new paste, assemble back the CPU and try again.
Recently my eMachine desktop computer with MIcrosoft Vista OS had an automatic upgrade to the Vista program installed and will not start-up properly now. It seems to get hung up in the loading process. It...
You can try to boot up in safe mode hitting F8 while computer is booting up after it is in safe mode go to control panel and then go to add and remove progams find the last update you install and remove it. If that is a no go you will have to restore to orginal with disc that came with emachine
2answers
I have a T3626 emachine that I replaced the drive.
check all your ground screws on the motherboard. If that doesn't work try booting it up with out the hard drive. if that doesn't work, pop out the BIOS battery and unplug your computer, let it sit for about a min. and put the battery back in and restart.
Cant boot my emachine 2984
Did you check the CMOS battery and the CPU fan. Those are two things that if aren't working the way they should be, then some computers will not boot up. Try this first then post a response if you still can't get it working.
Startup disk
http://www.recovery-cds.com/laptop/search.asp?keywords=eMachine+Boot+CD+Disk&recor=1
http://www.spotmau.com/products/package/full.htm?gclid=CJvTiaOn0ZQCFRIdagod8gUbkg
2answers
Emachine doesnt turn on
contact me for support on these computers free of charge at [email protected]
Chris
Rebuilding emachine - windows 98SE
A C100 error is a registry error. I suggest that U format the drive and reinstall the 98SE. There are programs (bought) available that may fix this problem, but another perferred choice would be to purchase a XP operating system. Boot up on the XP cd and replace the 98SE with the XP. It's better, faster, prettier and more reliable.
Grand Canyon Tech
Grand Canyon Tech
