Nikon Coolpix 2200 Digital Camera Logo
A
Anonymous Posted on May 15, 2010
Nikon S220. Lens error. Turns on but displays lens error only.. Cannot take pics
Arjun Komath
Level 3:
  • Master 1,170 Answers
  • Posted on May 31, 2010
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439677
Points
3355
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
My nikon coolpix s220 have a lens error and when i turn it onthe lens goes in and out like its trying to focus and it makes a wierd noise. it also wont let me do anything it just pops up saying lens error
Try removing the battery/batteries and clean the contacts underneath. Also, clean the battery contacts and the charger, if so equipt. To do this, dampen a cotton swab with rubbing alcohol and rub the contacts. Blow into the compartment after to clear any residue.Thanks, Dana
1helpful
I have a nikon coolpix s220. when i turn it on it trys to focus and cannot. it then gives me "lens error" message and turns it's self off. is this fixable? your help is greatly appreciated. ...
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
6helpful
Nikon s220 lens error
The s220 seems to be very susceptible to lens errors, usually associated with the lens barrel being unaligned. It only takes the slightest bump/drop in many cases. Fixing it is a hit or miss solution. http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html Has a good list of possible fixes.
2answers
Re Nikon S220 digital camera. Lens error noted -
A tiny bit of grit can jam the gears of the lens. Sometimes a tap can knock it out. Try this at your own risk. Take out the batteries. Don't hit the camera on a hard surface, just use you hand. If it hurts, that is too hard. Try lens down, then all the sides.
5helpful
Lens error in nikon s220 digital camera.
Yes you right. After fall down the lens internal guide pin is damaged and thats why its happens. a912d76.jpg So visit your nearest service center for repair. Thanks.
3helpful
S220 Coolpix has a lens error problem, turn camera on tries to focus (Lens moves in and out making a weird noise) but comes up with a lens error problem
Did it drop? sounds like the motor is trying to move the lens as you need, but the lens has come out of its tracking. If there is no outside damage and you still have warranty left, you should get it replaced, otherwise it means opening it to place the lens back on its tracking, but this can be tricky.
Ok ive had my camera for maybe one week its a nikon coolpix s220
Try jiggling the lens. Use compressed air to blow out any grit around the lens barrel. If that doesn't do it, you'll need to get the camera serviced.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
