Toshiba QOSMIO E15-AV101 Notebook Logo
A
Anonymous Posted on Aug 27, 2017
QOSMIO E15-AV101 PC Notebook: just installed windows 7 ultimate, clean install, ...
Just installed windows 7 ultimate clean install on my Toshiba E15-av101. I'm trying to connect to the internet to update drivers but i can't get the notebook to connect to the internet. I've tried using a router I've tried connecting directly thru my cable modem...i can't get anything. The device manager does pick up the network adapter. Anything help would be greatly appreciated.
john_marcus
Level 1:
New Friend:
  • Contributor 17 Answers
  • Posted on Aug 27, 2017
john_marcus
Contributor
Level 1:
New Friend:
Answers
17
Questions
0
Helped
2833
Points
54
Okay in some case windows 7 does not pick up the network drivers so you will need to download and install the network drivers for your laptop from another computer and then copy those files to a pen drive and then connect it to your laptop and install it, however I do see that your laptop driver support page does not support other OS other than windows XP32. Please refer the link below and download both the drivers and install it, that is the driver for windows XP it should probably get installed and work for windows 7.
http://support.toshiba.com/support/modelHome?freeText=804518&osId=50
1helpful
How to restore toshiba qosmio e15 av101
Unless you have a installation, Win XP?, CD/CD's or Factory Recovery CD/CD's, it will not Restore on a blank HDD. If I understand your question correctly. You must do a FULL installation.
How to do a hard reset on my toshiba e15 av101
hard reset is done by shutting down the computer. Then remove the cables and battery to it, and then press and hold power button for 8 secs. Reinsert the cables and battery into it, then turn it back on..
Hello i have a problem with the FN keys and the touchpad of toshiba qosmio x305 q715, i install w7 ultimate x32 and the drivers from the toshiba homepage but didn't work . Thanks
Hi
please tell us what operating system was on there before you installed windows 7
please add comment below also telling us what drivers you are looking for
many thanks
1helpful
How do i remove back and reinstall fan?
Welcome to Fixya
Here's the procedure:
1. Shutdown the laptop and remove the AC adapter. Disconnect any devices, such as a printer or external DVD-ROM or drive, that are attached to the laptop
2. Remove the laptop battery. Turn the laptop upside down, slide the battery release latch and then pull the battery out of the bay.
3. Unscrew the hard drive cover. Grab the hard drive tab and shift the hard drive to the left to unplug it. Lift the hard drive out of the bay.
4. Unscrew and remove the PCI memory cover, the optical drive cover, and switch cover.
5. Unscrew the two screws that hold the keyboard to the base, these are located in the middle of the rear panel. Flip the laptop over so it is right side up, open and remove the keyboard by using the keyboard release switches located above the keyboard. Next, unplug the Toshiba Qosmio E15-AV101 Fan cable.
6. Close the laptop and turn it over so it is bottom up. Unscrew the display assembly screws located under the laptop screen hinges. Turn the laptop over so it is right side up. Open the laptop and unplug the display assembly cable and disconnect the wireless antenna from the display assembly. Unscrew the display assembly from the laptop base and remove.
7. Unplug the mouse pad cable. Turn the laptop over so the bottom side is up and unscrew the base screws which are located along all four sides of the laptop base. Gently remove the base of the laptop.
8. Turn the laptop over so it is right side up. Unplug the fan cable from the circuit board. Unscrew the screws holding the Toshiba Qosmio E15-AV101 CPU fan assembly to the laptop. Lift the fan assembly out of the laptop.
9. Insert the new Toshiba Qosmio E15-AV101 CPU fan assembly into the lap top. Screw the assembly unit to the lap top and plug the Toshiba Qosmio E15-AV101 CPU cooling fan cable into the circuit board.
10. Reassemble the laptop by repeating the previous steps in reverse order.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
1helpful
How to rplace cpu fan for toshiba qosmio e15
See the below video for guidance on how to take apart your laptop.
1helpful
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Why is my screen blank
thats weird. try restoring the computer, st the splash startup screen, press F11 then release it. follow onscreen instructions to restore the computer to factory setup
I have Qosmio E15 and it wont boot
Go here: http://www.hitachigst.com/hdd/support/download.htm#DFT And download the drive fitness test, burn it to a .ISO bootable CD, and boot from the disc. Run a FULL SCAN and it will tell you if the HDD is bad, which is highly likely.
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
