Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
A model number would have helped, but I can give you a generic answer. It may be a bad door switch or mount. (Anybody in the home opening the door while it's cooking?) See our help file on door switches here.
Usually when a microwave's fuse blows, it will be dead, not partially functioning. It may be a bad door switch or mount. (Anybody in the home opening the door while it's cooking?) See our help file on door switches here.
The magnetron (the part that heats the food) may be bad or the circuitry to the magnetron may have burned out. Basically my advice is that if you have no electrical expertise, it isn't worth fixing. The magnetron if bad, costs almost as much as a new microwave. If you open it up (make sure it has been unplugged for a few hours and don't seen any obvious burnt parts, then most likely the magnetron is done and a new microwave is the way to go.
We have had problems like this before. Most likely the smartboard is defective.Check with manufacture to see if there is a recall.You should be able to find them on the web.
