I have purchased 2 years back SONY DSC T70 camera but few days back onwards when moving lens cover down vertical straks appearing on LCD and when we switched off & on after 10 minutes it will ok & working properly 2-3 times but again same problem happening plese tel me the exact reason whether software fault or parts?----- vinay
SOURCE: Sony DSC-T70 CyberShot memory/battery cover broken
Assuming that your Sony DSC-t70 has black color cabinet then you need battery Compartment with following part number...
X-2186-609-1 ASSY, BTH (B) (BLACK)
IMPORTANT (If camera has different color cabinet, let me know to provide you appropriate part number)
Above said part is available in Part Store on $33.42
Yes, why not..
Here is silver color battery compartment part number of DSC-T70
X21866081 ASSY BTH (S)
It is available in Part Store.
Please rate this and previous solution with 4 blue diamonds if you found them correct.
SOURCE: Sony DSC-T70 still takes pictures but screen off
Since you've already swapped the screen, it looks like there is an issue with your logic board. However many times ebay vendors send you a screen that will fit but is incompatible, so I wouldn't exclude that possibility. I work for Sony Repair NYC and we do this repair frequently.
SOURCE: Sony dsc-t70 camara vibrates when turn on
it's actually a failure with the lens mechanism, I just experienced the same situation....Sony has another T20 that they had the same situation with and they offered to fix the cameras until July 2011..currently checking if Sony will fix this defect in this T70
what you are experiencing probably is best described by this article:
www.sonyinsider.com/.../dsc-t20-cyber-shot-camera-vibration/
