Kodak Easyshare CD82 Digital Camera Logo
Posted on May 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens error Everytime i turn on my camera it says lens error:211
Kiran Anto
Level 2:
  • Expert 420 Answers
  • Posted on Sep 11, 2010
Kiran Anto
Expert
Level 2:
Answers
420
Questions
Helped
115429
Points
910
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Lens error 211
Here are troubleshooting steps for a lens error.
and here's a video summary of the steps:
Lens errol 211
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
6helpful
3answers
Kodak easy share c182"lens error 211" will not
I went with other advice, gentle drop on carpet sorted it :-)
What dose lens error 211 mean?
A repair. There is a fault within the lens mechanism.
Please also try to upload new firmware: I doubt that it will solve the issue, but the alternative is a repair.
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11895&product=EKN034494
M425-12 lens error
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2helpful
It has a lens error. Everytime the camera is turned on it beeps and clicks constantly. It eventually shuts off after displaying "Lens error, restart camera." on the screen.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
My digital camera say lens error:21 how do i repiar the lens? sanyo vpc-e760 My SANYO VPC-S650 says lens error:507 everytime I turn the camera on. The lens has not returned back to normal position, and...
The lens has a servo fault. This can be either the lens motor, the helicoil in the lens is jamming, or the servo drive electronics has a fault.
You will have to send the camera for service if you want to fix this. I doubt you can fix this yourself unless you have access to the parts, and have the training and tools to do this type of service.
Jerry G.
It says lens error
its probably broken but the black slides that cover the lens if you play with it alot or push them in when the camera's turned off the lens mess up or if you've dropped the camera too much the lens break on the inside.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
