The unit is most likely getting too hot. Check your speaker cables for frayed wires that may be touching each other. The amp will continue to work, but work much harder into a lower impedence load. Over time this will damage the amp. If the cables are OK, try running the amp with the speaker wires disconnected. If the unit still behaves the same way, there is a problem internally with the output section that should be corrected ASAP.
Dan
