Question about Linksys WRT160N Wireless Router
If the wireless router is connected to the PC
If the wireless router (Linksys WRT160N) is connected to the PC running Windows 7, the internet is not available. Occasionally on the Toshiba laptop, internet connection not available.
    Habit-Forming:
    New Friend:
  • 10 Answers
Some few months ago i am also faced this same issued with my Netgear Router as it was unable to connect with internet connection.At that time one of my friend suggest me to follow this link: https://www.netgearroutersupportnumber.com/ , so today i also suggest you to follow this above link to resolve your query.
Posted on Sep 21, 2018
  • Linksys Master
  • 2,277 Answers
You are using WRT160N router. This router has issues with the firmware.
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
Posted on May 17, 2010
Anonymous
SOURCE:
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Linksys wrt160n router. wireless xbox won't connect
I made it an unsecured connection and everything worked. Not ideal solution, but it worked.
Feb 07, 2010 | Linksys WRT160N Wireless Router
Linksys wrt160n will not broadcast the internet wireless or ethernet it will however broadcast a connection to the router not the internet. I have tried to re-set it, power down, nothing works. I have not...
Your Linksys WRT160N is a router that can be accessed via CAT-5 cables and wirelessly. You must configure the router though, for wireless use. If this is not configured or not configured correctly, then you may have problems using it wirelessly. Laptop computers usually use the 802.11g mode, not the 802.11n, at 54MB or with the right NIC in a desktop you can get 108MB. If it was working then quit without your doing anything, you may have to replace the router, but I doubt it.
Nov 08, 2009 | Linksys WRT160N Wireless Router
Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
Oct 01, 2009 | Linksys WRT160N Wireless Router
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Router installation
THis can be a problem with the wireless settings of your router, I believe your laptop is trying to connect wirelessly to your router, This can be solve by accessing the router setup page and do some changes on its wireless settings settings like the SSID and the most important one the wireless security..If you're not familiar on how to do that I will advcie you to call LInksys tech support so one of their tech can walk your through with that process, they are open 24/7 this is the number 800-3267114.......
Hope that helps.........
Sep 16, 2008 | Linksys Wireless-N WRT150N Router
Linksys WRT160N Wireless Router  Logo
230 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
