RIM BlackBerry Pearl Flip 8220 Cellular Phone Logo
Posted on May 16, 2010
Enable bluetooth Can't seem to enable bluetooth - Do I need to download something?
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 18, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
535
Points
My blackberry 8220 flip, blutooth can pair with my laptop, and send the phone list, but the phone cannot receive photo,s etc
2answers
How do i turn on the bluetooth on a dell latitude e5410
This link should be helpful. Dell website for all things Bluetooth. You may also need to download Bluetooth stack.
2helpful
I'm having problems with my Bluetooth adapter or the Bluetooth technology built into my computer Sony VIO VGN-CR34GN
Please, be precise. What kind of problem do you have? Having poblem enabling bluetooth device? Or your bluetooth device enabled and you can't transfer files?
If your bluetooth device isn't enabled, go to control panel and check if device is installed correctly. (bluetooth device mustn't have yellow mark).
If your bluetooth device have yellow mark in control panel, that means you need drivers for this device. You can install drivers from your laptop's CD. If you don't get CD, no problem, download it here: http://www.all-driver.com/downloading/http://download.sony-asia.com/vaio/downloads/Original_Drivers/073Q/VGN-CR3/drivers/Bluetooth.EXE
Follow installation instructions and you are done.
My Macbook is bluetooth capable. My PIXM MP480 seems to be bluetooth equipped. Can't get the two to communicate. Do I need some other piece of hardware to make it work?
The printer Canon PIXM MP480 is bluetooth enabled ( which is optional ) but it is not fully functional without a Bluetooth unit BU-30 ( bluetooth dongle )
The printer has Bluetooth enabled adapter which means you will need a bluetooth dongle to make it work with your Macbook. You will have to connect the Canon Bluetooth unit BU-30 to the printer and enable to bluetooth function on the printer to be detected by your macbook.
You will be able to purchase the Canon Bluetooth unit BU-30 at any nearest stores ( bestbuy, walmart, costco etc ) for a price of $30 to $50 Approx. depending on the offers you will avail from different merchants/stores.
Hope this answer was helpful.
How can i download pictures from my lg to pc. I downloaded the soft ware but cannot connect
Thes best way of to enable your blue tooth on both the PC and the phone. Once it is detected you can send pictures to be accepted by the PC .
In the phone open menu, connctivity- enable Bluetooth.
Inthe PC enable Bluetooth- bluetooth settings.
I have a hp pavilion dv9000. it had an bluetooth icon.. but now it seems to be disabled . how do i enable the bluetooth again.. everytime i try ...it shows an error... help lpz
If enabling blue tooth from the keyboard does not work anymore, then you usually need to reinstall Bluetooth drivers again.
to download drivers click on the link below, select the model, select the operative system version, then select Network Driver and reinstall bluetooth drivers from there.
HP Pavilion dv9000 Entertainment Notebook PC series - Download
If this does not solve the problem, then the bluetooth module ( a mini PCI card) may be defective. In that case an opriton could be installing an external bluetooth: TRENDnet TBW-105UB Network adapter - USB
2helpful
I need to turn on bluetooth on my VAIO VGN CR353
When you have the wireless antena turned on the bluetooth comes on with it, unless it has been disabled. To enable it you should have an icon in the lower right that says LAN. Double click the icon and you will see the option to enable Bluetooth or change from 2.4 to 5 ghz wireless. All you need to do is enable the bluetooth.
2answers
I dont know how to disable bluetooth off on my Samsung SPH-M300
well what you do is that you go onto the buetooth mode and then it should sya something like disbale and able
I need down load photos off of my lg f1420 mobile phone
If it isn't Bluetooth enabled, best way is to use an SD card, save photos to it and download to PC using a card reader. If Bluetooth enabled, you need a Bluetooth dongle.
1helpful
Bluetooth...Help
first try to check in the program files if you have bluetooth installed.
start >> programs >>bluetooth >> bluetooth settings
look for the menu were you can activate the bluetooth.
also you can try. looking in the system tray icons. you will see the blueetooth icon in color red when it is disabled...right click on the icon and choose enable bluetooth radio.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
