SanDisk Sansa e250 MP3 Player Logo
A
Anonymous Posted on May 14, 2010
Won't read mini sd...can't see the songs on the sd card.
Anonymous
Level 3:
  • Master 593 Answers
  • Posted on May 17, 2010
Anonymous
Master
Level 3:
Answers
593
Questions
0
Helped
175305
Points
1850
You need to check the settings in the players USB mode. Set the player for MSC mode and any thing you copy on to the SD card should be there..
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
1helpful
I have the a Casio Keyboard that has an SD slot, but whenever i put songs on my SD card & then plug it into the keyboard, it says that there is an ERROR . What am i supposed to do . Step by Step . to...
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
  1. Insert your sd card into computer
  2. Make folder called MUSICDAT.
  3. Then, transfer all files inside the folder (make sure your songs are in MIDI format).
  4. Safely remove your sd card.
  5. You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
2helpful
My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
  1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
  2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
  3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
  4. Right-click on the drive and select the "Format" option. A menu window will open.
  5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
  6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
WARNING
  • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
  • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
Garmin nuvi 360 can't read sd card
Make sure you format first the sd card and then the maximum giga byte is 2 mb and the minimum is 16 mb.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
Mp3 memory expansion
Yes there are other mini SD cards with higher memory but before you purchase be sure its compatible with your player. You can also save your songs or other datas in your computer, if you dont have other options. you can change the songs that are saved in your player using your computer in that way you dont need an extra SD card.
SD Card reading problem
Problem is your SD adapter for your mini SD card!!! Try with other and you will see that will work.
good luck
How do i put songs on the mini sd card i bought for my Sandisk sansa connect mp3 player
I'm not sure but you should be able to find the settings for saving data in it's menu and change the location from internal/onboard to memory card.
I hope this helps, and Good Luck.
1helpful
3answers
Micro sd card not reading songs
Yes, Brother there is one probability that your sd is formatted in fat-32 file system. For that i would like to say phone can only read FAT not FAT-32. Go to my computer, select sd drive properties and format it with FAT file system. Then load the files and you will be able to see it in your phone. If it works don't forget to vote here. For any proble contact me [email protected] or [email protected]
SD card in MP3 player
SD card = too big for player to read. Get a smaller SD card.
Can't make a playlist
all you need to do is to format the mini sd card, and use USB cable to drag or copy and past mp3 audio files into your mini sd card. automatically it will allow you to make play list
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
