Whirlpool GY398LXPS Electric Kitchen Range Logo
A
Anonymous Posted on May 14, 2010
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
Anonymous
Level 3:
  • Master 15,935 Answers
  • Posted on Oct 01, 2010
Anonymous
Master
Level 3:
Answers
15935
Questions
19
Helped
5033299
Points
35540
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
1helpful
Display reads EO -F2- stove top works, oven will not
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
1helpful
My kitchenaid keri203 is showing E0 in orange and F2 in blue on my oven display
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!@@
When I press my power button 3 or 4 time (on off) or some time more then display show in monitor. when I press 1st time then the pc start but no display show in monitor. when I off it and then again on it...
CHANGE CMOS BATTERY OF YOUR SYSTEM IT COSTS 10 RUPEES ONLY. ERRORS WILL GONE AFTER CHANGING THIS BATTERY. SYS WILL START IN SECONDS AND F2 ERROR WILL DISAPPEAR
Hi, this error code indicates a shorted key on the touch pad.
1. Check keypad connector for firm connection also clean with a pencil eraser (keypad connects to control board).
I you have any other questions please feel free to ask. Mike
6helpful
Kenmore Elite Oasis HE washer error code F2
The error code must be cleared first to make the machine back into operation. You have to press the PAUSE/CANCEL button twice to clear the error on the display.
The only filter the machine has is the one you removed to clean the pump. When the error is cleared, you can check the pump whether it is operating properly or not by running the diagnostic test.
Diagnostic Test Mode Procedure
  1. Close the door.
  2. Select the DRAIN/SPIN.
  3. Select NO SPIN by pressing the SPIN SELECT button.
  4. Press RINSE/HOLD or PREWASH OPTION button four times within five seconds.
  5. "C:00" will show on the display indicating that the door is locked and the diagnostic test starts.
  6. Press the button you pressed in step 4 above two times. "C:01" will show on the display and the machine starts to fill.
  7. Press PAUSE/CANCEL button two times when there's enough water inside the tub to stop the test.
  8. Observe the water level falls as the pump starts draining the water. Replace the pump if the water inside the tub does not drain. You have removed and cleaned the pump so you can easily replace it too.
Please inform me about the result of the diagnostic test and if you still need any assistance regarding this problem.
1helpful
Code E0 and F2 with a little lock displayed on touch board of Whirlpool Gas Range. burners work but unable to operate the oven
You will need to press the cancel/stop button, this will clear the display and you will be allow to use the oven. If this does not work yoy will have to unplug the stove for five minutes and then plug back up and this should clear the display and allow the oven to work.
Nov 14, 2009 • Ovens
Kenmore electric Range model 635040L0
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@@@@
8helpful
Kitchenaid Oven won't work E0 F2 on the control pad
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@#$
7helpful
3answers
Whilrpool Self Cleaning Range Door won't unlock
try this 1. Verify error code by pressing and holding CANCEL/OFF key for 5 seconds.
Momentarily (less than 5 sec.) press CANCEL key again to remove error code
display.
2. Press and hold any key for 1 minute until F2 E0 code is displayed.
3. Cancel F2 E0 error code.
4. Program and start the clean mode. Observe to see if door locks. If it does not,
inspect the locking mechanism from the solenoid to the latch pawl and door to
find the cause of the problem. If the door is not locking, then 1 minute from the
start of clean, the F5 E1 code will again be displayed. Steps 1 through 3 will
have to be repeated before another clean can be started.
5. Once any mechanical problems with the latch mechanism have been corrected,
program and start a clean cycle (after, if necessary, clearing F5 E1 error code)
to ensure proper operation of the door lock. Immediately cancel the clean mode to observe proper operation of door unlock
3helpful
2answers
Hotpoint aqurius wf620
Switch on the machine and presss the start/cancel button this should take the "test" off the display. Then press and hold both the start/cancel and on/off buttons for a few seconds. The display will show d off and then the waher will work as normal.
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
