Goodman GMS90703BXA Heater Logo
A
Anonymous Posted on May 14, 2010
Goodman furnace model # GMNT100-4B On vacation neighbor checked house house filled with gas. He shut off main and furnace. Came home turned on gas to everything except furnace. All good. Furnace will not light. The indicator light is solid red. Any suggestions on next troubleshooting step. Thanks.
Anonymous
Level 2:
New Friend:
  • Expert 53 Answers
  • Posted on May 16, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
53
Questions
0
Helped
22996
Points
103
From my experience with goodman units ,it could have been a gas supply problem there are so many protective sensors that i dont think it is the unit by the way is it electronic ignitor or pilot
Goodman furnace model #capf030b2c 4 blink code blower runs constant but no heat
https://hvac-boss.com/troubleshooting/goodman-furnace-error-codes/
According to this page, you can usually fix this 4 blink diagnosed problem by changing the air filter or tightening wiring (which it has a cautionary warning about tightening such too much) and checking the flue for blockage. The furnace has activated the primary open limit circuit.
Here is a troubleshooting page about the Goodman just blowing cold air: https://temperaturemaster.com/goodman-furnace-troubleshooting/#Goodman_Furnace_Blowing_Cold_Air
Poor air flow in the Goodman caused by blockages can result in the tripping of the rollover switches which would cause it to blow cold air. That is a safety measure. You don't want gas furnaces burning with insufficient air. Think carbon monoxide. Besides the air filter, the flame sensor or the burner could be dirty. The idea of trying to DYI that cleaning job is rather off putting. I hope changing the filter would work.
I trust it is not a fuse in the pilot flame sensor circuit blown. A repairman has the voltage testers for checking the electronics involved.
I can empathize with this. My furnace, another brand, went out recently. The repair man didn't know why it went out but simply adjusted a handle controlling gas flow to a position slightly different from what was recommended and it worked. All for $200.
https://www.repairclinic.com/RepairHelp/Furnace-Repair/36-377--/Goodman-Furnace-Troubleshooting
https://www.youtube.com/watch?v=zO1jKqwXu8s
https://www.goodmanmfg.com/products/gas-furnaces
1helpful
3answers
Need wiring schematics for goodman manufacture model # A60-20REV/C gas furnace
Here is a diagram containing the Wiring Schematics for Goodman Gas Furnace
My Goodman furnace is not firing. The red light is on, the igniter is heating up, but no flames. I have gas to the house as my gas dryer is working. What could be the issue?
Check to see if your furnace has an exhaust fan, if it does, make sure it is coming on. If it's not, the furnace will not light.
Goodman dependable 92 light for 6 sec out reignights after 45 sec it does it about 4 times then nothing i turn the pwr on and of thought might be the thermocoupler or flm sensors storm knocked out air
be carefull
only found these
DF]Service Instructions - HVACPartsShop
www.hvacpartsshop.com/manuals/gmph050-3.pdf
Goodman Dependable 92 Furnace Manual - PDF documents
www.do-cu-cu.com/Goodman-Dependable-92-Furnace-Manual.pdf Goodman dependable 92 furnace manual shop for goodman gas furnace repair parts for model gmpn1004 at sears partsdirect. find parts, manuals & diagrams ...
Goodman gas heater model GUE080-4 . pilot lighs , but furnace will not . Electronic pilot lights & stays on for about 1 min, than shuts off seems main gas relay not switching on.need manual
Check roll out switches located around burner compartment.
there is a small square button between the wire terminals press firmly down on it to rest switches. If this solves the problem have the furnace cleaned and checked by a professional HVAC technician.
Bob
My Goodman GMS9/GCS9 Gas-Fired Furnace is not working.?
Check all safety switches on door. Make sure the main breaker in fuse box is on and well as main switch on furnace. Please ad more details. New install, just quit working? How old....
Goodman furnace model # GMNT100-4B On vacation, neighbor checked house, house filled with gas. He shut off main and furnace. came home turned on gas to everything except furnace. All good. Furnace will...
Solid red typically means bad controller. Try unplugging the furnace, wait about 30 secs, then plug it back in. The possibility that the controller was sending voltage to the valve even when there was no flame is a bad sign. If the controller starts the furnace, watch it very closely and see what it does. If the solid light comes back on, it's time for a new board.
Goodman gas furnace power vent motor and housing replacement
You need to type GOODMAN GAS APPLIANCES into you browser to find you local servicecenter. I must tell you that Goodman only sells to authorized service companies in my experience. So you become EgKraft Company.
Top Goodman Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
