Pentax Program Plus 35mm SLR Camera Logo
Posted on May 16, 2010
Shutter wont close
Bought cam from a friend who got it from his dad. New batteries but shutter won't work. I can **** it by opening the back then closing it again. Shutter cocks but it won't open or close even with film loaded.
Anonymous
Level 1:
New Friend:
  • Contributor 55 Answers
  • Posted on Jun 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
55
Questions
0
Helped
19068
Points
81
Try setting the shutter to B and see if you can trip the shutter. If no go then it has mechanical problem. If it works on B but not on other shutter speeds, you have electronic problems.
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
In anything but full automatic, the shutter opens but won't close unless I press the shudder release button again
is sounds like you have the shutter set on bulb.. try changing the shutter speed and see if this helps....
My lens won't open
The gear linkage in the lens is seized or is out of alignment, this is a job for a camera specialist, I recommend estimate first.
My Nikon Coolpix 8700 wont turn on!
Try another battery. Even though you bought a new battery and charged it doesn't mean it is not bad.
Jul 17, 2009 • Cameras
Re: Shutter Wont click
Hi , check everything set c amera speed to 60/seconds auto or manual / check also the the camera shutter blade , open the lense and close to activate the shutter blade .
My camera wont work right
did you mean the shutter wouldn't open and close?
if yes, this is common to most cameras idled for years. the shutter curtain or leaves stuck, or the electronic unit that powers the shutter mulfunction.
eBay sellers are not always honest. return it if you are lucky or file a complaint. let me tell you about my experience there. i bought a used Yashica, but when it arrived, some parts went wrong enenthough i specifically asked, the condition was not as stated, and lens cap seen on pic was not included. the seller was a kind of rude manner, he just refused to admit though eBay suspended him from trading.
3answers
My friend droped my cam and wont turn on!!!
If your friend dropped it the in they are a good frien thay will ofer to replace it. Any repair even if one were possible and oftern they are not will be costly.
So a Good friend will go buy you the replacement
Shutter won't close on Nikon D70s
Format the card. I have same problem with mine ---requires a new shutter assembly.$40.00 item and they want $300.00 to fix it at Henry`s cameras. Ouch .Better to buy a new camera.
2answers
Camera shuts down when the flash is opened
the flash circuit of the camera is short. the moment you switch on the flash it drops the supply voltages of the battery. you have to show it to a repairer.
Top Pentax Photography Experts
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
