Black & Decker HS2776 7-Cup Rice Cooker Logo
Posted on May 15, 2010
Where can I find recipes to use the HS2776 6-cup rice cooker? How do I cook rice?
5 Related Answers
Anonymous
  • Posted on Feb 28, 2009
SOURCE: Measurements for Rice
Most of my experience with the rice cookers is that they require a japanese rice Cup which is different than the japanese regular cup. makes a whole lot of not sense but i found a replacement cup at one of the local Japanese Markets if you had to you could use regular measuring cup and use the 160ml for your measure. also the cup has a "Inomata" on it so maybe the web can help you
Eat lots of Rice
Anonymous
  • Posted on Apr 07, 2009
SOURCE: Rice Measurements
You use one cup of water for each cup of uncooked rice. You end up with about 2 cups of cooked rice for every cup of uncooked rice. Different varieties, such as brown rice, take more water, up to 2 cups of water per cup of uncooked rice. If the resulting rice is too dry, you can add more water and restart the cooker.
I am not sure, but I believe that 16 cups refers to cooked rice, so you should not put more than 8 cups of uncooked rice in the cooker.
Anonymous
  • 4 Answers
  • Posted on Jan 08, 2010
SOURCE: I need cooking instructions for RC3406 6 cup rice cooker
I ran into the same problem locating this manual. Black and Decker has the manual for the 3 cup on their site but not the 6 cup. I did find a manual for the Rival brand version which appears to be the same thing. You can find it at the URL
http://www.rivalproducts.com/manuals/MANUALS/RC61_43_53194273.PDF
Anonymous
  • 4 Answers
  • Posted on Jan 17, 2010
SOURCE: black and decker flaver scenter rice cooker manuel
http://www.useandcaremanuals.com/pdf/HS80035.pdf
is the pdf of the manual for this product
Mike Schneider
  • 245 Answers
  • Posted on Jan 25, 2010
SOURCE: I have lost the measuring cup for Black &
it tales you on the box.
How much water to one half cup of jasmine rice
Hello, Steve -
If you are cooking the jasmine rice the traditional way on a stove, the ratio of rice to water is:
3/4 cups of water to 1/2 cup of rice (per most instructions on packages); for softer rice, add just a little bit more water, plus it is recommended to rinse the rice and drain it prior to cooking
See:
https://www.onceuponachef.com/recipes/perfect-jasmine-rice.html
If you are using an electric rice cooker, the rice to water ration is:
1/2 cup of rice to 1/2 cup of water; rinse and drain the rice prior to cooking
See:
https://www.wikihow.com/Make-Jasmine-Rice-in-a-Rice-Cooker
Best wishes.
May 01, 2018 • Cooking
1helpful
Is this 10 cups raw or cooked rice?
Hi Jane:
Don't have any info about your question but,
if you start with 10 cups of raw (uncooked) rice you will end up wit a LOT of cooked rice.
I'd suggest that you re-read the instructions for the recipe or whatever it is you're up to.
Hope it's a raisin rice pudding.
MMMMMMMMM.
How to cook in the slow cooker
Most slow cooker recipes are very straightforward. You put the ingredients in, and select your cooking time. Most slow cookers have slow (8+ hrs) and fast (4-6 hrs) options. Here is a site with a wide range of recipes. http://allrecipes.com/recipes/main-dish/slow-cooker/
LOST RECIPE JUST WANT TO COOK RICE
Visit http://www.wolfgangpuck.com, You can check cooking recipe there.
I need the recipe for cooking rice in Crystalia Steamer/Rice Cooker
The general rule for cooking rice whether its in a rice cooker or a deep pan is to rinse the rice three times, put the same amount of water in the cooker (1 cup water to 1 cup rice). Turn on the cooker, let the rice cooker complete its cycle. Let the rice sit in the cooker for 10-15 minutes to steam. Serve.
You can vary the amount of water depending upon whether you want drier or moister rice. Enjoy.
4helpful
Cooking PLAIN rice
Here is my recipe - enjoy and please rate my answer as a fixya!
Raw Rice - 2 Cups (400 gms.)
Water - 6 Cups.
(The ratio of rice to water is 1:3)
PROCEDURE
Step 1:First wash the rice in water thoroughly and drain the water.
Step 2:Take a vessel ,the capacity of which is double the quantity of raw rice that is to be taken.
Step 3:Now,add the washed rice into this vessel and pour 6 cups of water into it .
Step 4:Now, place this vessel containing rice with water in a pressure cooker and add the pressure weight on the cooker top.
Step 5:Heat the pressure cooker for 20 minutes only.
Rice has been cooked.
NOTE:
*After heating the cooker for 20 minutes,donot open the cooker immediately.Wait for 15 minutes and then open ,otherwise the cooker would burst open.
1helpful
Top Black & Decker Kitchen Appliances - Others Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Black & Decker Kitchen Appliances - Other Expert? Answer questions, earn points and help others
