Make sure there is no blockage of the burner near where the spark jumps. All it takes is a drop of water to stop the gas flow near the spark. Most likely you can use a knife or some other thin blade to clear the slots where the flame comes out of the burner.
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Hi If the burner is not burning hot, and there is a low flame then this is often a pressure regulator problem. Most often the regulator is found where the gas line enters the gas range. I have a picture of what the flame characteristics should look like.If the igniter on different burner doesn’t work, and there is no spark at that burner then you will have to check the same items as mentioned above. This is a typical spark module wire diagram. Please do accept the solution if the issue is resolved or else revert for further assistance. Thanks Rylee
Check that the burner orifice nozzle (the round thing that comes off) is properly seated on the burner manifold. Mine have a tab that must interlock.
Make sure all your burner orifices are CLEAN. Scrub them with a plastic kitchen scrubber, soap and water.
The way this works is, when a burner is turned on, the sensing mechanism for the spark control reads the ionization of the flame. No flame, no ionization, keep sparking so gas buildup is minimal in the area before a flame is ignited. )Kinda like the spark thingy's underneath the shuttle, without the ionization sensor's, just before it launches.).
Lowly what the potentior does is turn on the burner control system. When you turn on a normal burner you are opening a gas valve and closing a switch to generate a spark. Thus gas flow to the burner and spark. On the extra low simmer burner there is a electric solenoid between the burner head and the gas valve. this has to open as well for gas to flow. What the potentior does is signal the simmer control what level of flame you are requesting and telling the spark module to generate a spark. Once you go to the exlow setting the potentior tells the simmer control what level of heat and will cycle the flame on and off. So when the burner knob was between low and extra low, the flame would cycle on and off. You have to seperate the top section of the cooktop from the burner box to change the potentior for it sits on top of the gas valve for that burner.
Clean the gas nozzle w/small wire are located at the back of the gas cook top /shut off the gas clean small gas nozzle clog / w moisture /rust dust and any foreing material.
