Audiovox VM9312 Car DVD Player Logo
A
Anonymous Posted on May 13, 2010
Where do i connect da pink wire
I got a jensen model vm9021ts.....i keep conectin da pink wire to da negetive but it doesnt work...it dont wana show da movie dats playin..wat should i do?
Anonymous
Level 1:
New Friend:
  • Contributor 15 Answers
  • Posted on May 20, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
15
Questions
0
Helped
12767
Points
33
Connect da pink wire to the ground wire on the stereo units wiring harness. This will tell it you are in park.
Shorty
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 20, 2016
Shorty
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
545
Points
Have the same model and everything the only problem is that i lost the plug were the antena remote and the amp remote
The pink wire doesnt go anywhere on my jensen mp 5000 in my cmping trailer
the pink wire is the switch wire for the parking brake which shuts the unit of whilst the parking brake is disengaged, if its disconnected then that should make the unit work all the time.
Check for loose wires on the red and yellow cables, also check the in-line fuse holder isn't loose.
2answers
Emergency parking wire for jensen vm9311ts
your parking brake wire from radio is pink .
1 take a toggle switch 12 volt dc and 20 amps
2 take the pink wire attach the wire to the top terminal of the toggle switch
3 take the bottom terminal and attach a black wire to it and ground the other side of wire you must have a good ground ...
then once this is done test the switch turn on dvd it a video and flip the switch up and down a couple of time to simulate the parking brake and the video should work ...
if this doesnt work email me and ill give you the relay diagram to connect a relay inline to activate video but im pretty sure it will ...
http://www.tintingbyfredjohnson.com go here to my online store and email me from contacts
4helpful
5answers
Have a jensen vm9021ts that wont feed in cd's, play them or eject
good day just look for a qualified technician to repair the mechanical problem in your car video player.
1helpful
I bout a jensen vm9223 and i want to play the video all the time how can i do it
i dont have this model so im not sure. but if there is a pink wire, connect it with the black wires when u hook it up
38helpful
6answers
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
2answers
Need to buy a remote for my Vm9021ts
For your first question. You need to ground the parking wire. I wouldn't bet money on it but I think it is either a pink or a green wire. You just need to figure out which one is the parking wire and ground it. You can go even further and hide a switch so that if the pigs see you, you can flip a switch and they won't know.
I hope this helped.
-Andrew Hawkins
Screen only work with reverse camera! booo!
It sound like you need to ground your parking brake wire.
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
