Samsung washing machine no workeing ? dL
The door was unlocked while the washer was running
dS
The door was opened while the washer was running
d5
FL
The washer failed to lock the door
Hr
Washer temperature control problem
Heater Relay Failure (on main PCB)
LO
The door will not unlock
5E
Washing machine has failed to drain the water
4E
Water fill time out
ND
Water Does Not Drain From Washer
NF
Water fill time out = No Fill
dE
Washing machine door detected as being open
UE
Washing machine has detected an imbalanced load
DC
Washing machine has imbalanced load and will not spin
3E
Motor fault detected
bE
Motor short error
OE
Washing machine has detected an overfill situation
LE
Water leak - Excessive SUDS - Bad water level switch
HE
Water heating error detected
tE
Water heating sensor (thermistor) error detected
IE
Water level sensor fault
CE
Abnormal water temperature detected
E1
Not filling in allocated time
E2
Pump won't empty - not draining
E3
Overflow - overfilling with water
E4
Out Of Balance (OOB) detected
E5
Water temp rising or falling too quickly
E6
E7
Pressure switch
E8
Temp too high on low temp washes
E9
Water leak, Water level has reduced
EA
Motor generator error
EB
Motor error
