iLO LCT32HA36 Television Logo
Posted on Mar 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
32 ilo lcd
Need manul.i hook up box from cable co and get no signal.hook cable directly to tv and i get signal ttv works fine.i need box to get hd
  • mrvan1942 Apr 08, 2008
    no cable box tv works with cable box i get no signalon component out and no signalon the hdmi
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Apr 07, 2008
Anonymous
Expert
Level 2:
Answers
149
Questions
0
Helped
39834
Points
236
Most boxes have component out or HDMI connection use either one and cable box or satelite came with instruccion on how to connect it ..
I have cable. The autoprogram doesn't recognize any channels. It works fine when I hook up the dvr cable box, but not when I bypass the box. Trying to do away with the box.
Cable signals today are encrypted so that it is not possible to directly connect the cable to the set and get the cable channels. You must use the cable box. Some sets have what is known as a "cablecard" slot that can be used with a card from the cable company in lieu of a cable box. Only then can you use the TV tuner for cable channels.
What do I do to get my signal back on my westinghouse TV that is hooked up to dish cable
If no signal via the cable fitting try hooking set via one of the sets of jacks on the back (audio/video or component) to see if coax input or tuner is bad.
If the set works with a DVD etc hooked to one of those inputs and your cable is good--maybe a bad tuner in the set---also if using a box try hooking cable direct to set to rule out the box.
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
LC-26DA5U 26 in. HDTV-Ready LCD Television: i connect a hdmi cable 2 my hd cable box - the pic...
The cable box needs to be set to send different signals when using hd tv and standard tv. Usually a good setting would be 720p in hd and 480p in standard. The tv is working fine it is the cable box sending the signal. If you have another hdmi source such as a dvd player you may hook that up to show the tv is working just fine.
Cannot get new digital signal to my ilo tv
I've done a little research and I don.t see where you have a ATSC tuner that receives the over the air digital signal. You have a basic Analog tuner. The only way you can receive digital is by a HD cable box by having cable or going to Satellite.
2answers
I was given this tv I need to connect cable
your t.v will hook up directly to cable. if you are asking how to hook to a digital box then you can hook it up the same as you had it hooked on your previous t.v. but if you want to get high def channels then you are going to have to take your digital box back to Time Warner and swap it for a high def digital box. or you can just call Time Warner and have a technician go to your house and swap/ hook things up for you. Hope this helps you.
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Hook up surround sound
if you are using a dirtv or other cable box, you should plug in the audio to your stereo from the cable box itself.
Power light just blinks
can you get a signal without box to tv
everythings going hd these days it could be they have it set for an hd
rf's pull there signal from the air and and filters to wear its supposed to go
hd is direct signals
9 times out of 10 the new box in not compatible with tv
or the guy who came in and installed the box did something to your tv and ran away
Cant get vcr to work
is your vcr capable of hd output? if not the picture will be a bit distorted(stretched)
Top iLO Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
