I have a lcd monitor came from japan and its quite different because its display cable is not VGA nor DVI. It's a digital cable,
i just want to ask if theres cable converter to it. A cable that has to cable ports, the other one is for the digital and the other one is for the DVI or VGA cable. So that the lcd monitor can now have a CPU set.
any answer is highly appreciated.
The monitor is a Fujitsu VL-15DX5G. 15 inch LCD.
The monitor cable uses a female DFP20 connector.
(Display Port 20-pin)
http://auction.thumbnail.image.rakuten.co.jp/@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
So you need a male DFP20 to male DVI-D adapter, or adapter cable.
DFP20 Male to plug into the monitor cable, and Male DVI-D (Dual) to plug into the graphics card's, female DVI-D connection.
So far, all I have found from a quick search is a Male DFP20 to Female DVI-D adapter, such as this example,
http://www.worldofcables.com/store/viewitem.asp?idproduct=768
Of course this won't do.
IF, this is all that's available for DFP20 adapters, you'll need an adapter of Male DVI-D to Male DVI-D, also. (Yes, I am aware of how crazy that sounds)
(It would appear, adapters are sold to connect a normal DVI-D monitor cable, {Male}, to a computer with a female DFP20 connector)
Should your searching only find DVI-D female to DFP20 male adapters, or adapter cables, then here is an example of a DVI-D male to DVI-D male adapter,
http://www.kvconnection.com/product-p/m-sgc-dvid-mm.htm
(DVI-D male to DVI-D male cable would probably be better as there would be less strain on the graphics card's DVI-D connection)
Sources:
http://babelfish.yahoo.com/translate_url...
Photo of the monitor cable connector enlarged, per your link,
http://auction.thumbnail.image.rakuten.c...@0_auc/image50/cb/4a/00010523850/a1/85/img00149858603.jpg
Display Port info from Wikipedia,
http://en.wikipedia.org/wiki/DisplayPort
It would be better to buy an LCD monitor that uses a DVI connector.
The Fujitsu monitor in your link is low budget, and low quality.
CPU stands for Central Processing Unit, or Microprocessor. Processor for short. Not computer. I need the Manufacturer name, and Model Number of the LCD monitor. Also, are you acquainted with the HDMI connector?http://en.wikipedia.org/wiki/HDMI (Post back in a Comment)
hi thanks for your reply, i think youre confuse of the term CPU set. What i think of CPU set is the motherboard, videocard, PSU, HSF, PROCESSOR, RAM, etc.
this is the link to the LCD monitor and its display cable wire. pls. reply. http://translate.google.com.ph/translate...
guys thanks for your reply. i really appreciated it, so can i use different CPU set using DFP?? where can i find this kind of DFP that will fit my cable.
