Canon PowerShot SX100 IS Digital Camera Logo
A
Anonymous Posted on May 12, 2010
I lost the cover for thecanon date battery
I lost the cover for the canon poershot sx110is date battery where can I buy one?
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Canon Master 102,366 Answers
  • Posted on Jun 14, 2010
Canon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444321
Points
622693
You can order one from http://uscamera.com/cd4-0816.htm
How do I remove the back from my Canon SX110IS? I have removed the 2 screws on the back above the lcd, one each on L and R of case, 2 below screen, one 1ach in A/V and battery compartments, but the back...
There are TWO screws on the right side, one is hiding under the cover for the USB connection!
Now you should be able to pop it off and... I'm guessing here... replace your cracked LCD screen. Good luck, hope this helps.
Thomas Drayton
Owner www.darntoothysam.com
Affordable Digital Camera Repair
3helpful
I have to reset date time etc everytime i turn camera on
If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
1. Confirm that the camera power is turned off.
2. Slide the memory card slot / battery cover lock and open the cover.
3. Hook your nail onto the date battery holder and lightly pull up.
4. Remove the battery holder in the direction indicated by the arrow. a570isbackupbatremove.gif 5. Remove the battery by pulling it up in the direction indicated by the arrow.
a570isbackupbat.gif 6. Insert a new battery with the (-) side facing up.
7. Replace the battery holder and close the memory card slot / battery cover.
8. When the Date/Time menu appears set the date and time.
12helpful
2answers
My wife is complaining that every time she turns off/on the camera she has to reset the data/time. I understand that when the batteries are changed the settings may be lost, but not simply when the camera...
Sounds to me that there may be another battery inside the camera that is going bad.
Issue: Everytime I power on the camera the Date / Time needs to be set.
Solution: Replacing the Date Battery for the PowerShot A480.
Replacing the Date Battery. If the Date/Time menu appears when the camera power is turned on, the date battery charge is low and the date and time settings have been lost. Please purchase a lithium coin battery (CR1220) and replace it as follows.
Please note that the first date battery may appear to expire relatively quickly after you purchase the camera. This is because it is installed in the camera at the point of manufacture, not when you make the purchase. caution.gifBe particularly careful to keep the date batteries out of the reach of children. Seek medical assistance immediately if a child swallows a battery since corrosive battery fluids can damage the stomach or intestinal walls. 1. Confirm that the camera power is turned off.
2. Open up the battery door / cover and remove the AA Batteries.
3. Remove the date/time battery holder.
4. Grasp the battery and slide it in the direction of the arrow.
a480backupbatt.jpg 5. Insert a new battery with the (+) side facing up.
6. Replace the battery holder and battery cover.
7. When the Date/Time menu appears set the date and time.
note.gif After purchasing the camera and turning on the power for the first time, although the Date/Time menu will appear, you do not need to replace the date battery. If you ever dispose of your camera, first remove the date battery for recycling according to the recycling system of your area.
2answers
How do I set the date and time on my Canon camera? It is a Canon Powershot SX110IS
To set the Date and Time, follow the instructions on page13 in the User Gide.
To set the camera to put date/time stamps on the photos, see instructions on pages 22-23.
I got to say that I just LOVE this camera! Had it twice - got stolen twice in South America! :(
Best regards,
Pelu.
3helpful
2answers
How to adjust date stamp for canon power shot sx110is camera? I need to have the date marked on the pictures.
You can download the user manual for the camera at
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=324&modelid=17480
To set the date stamp:
1. press the power button
2. select a shooting mode.
a. set the dial mode to Auto
3. select 2M
a. press the Func/Set button
b. use the up and down arrow to select "L"
c. use the right and left arrow to select the "check"
4. press the DISP button to switch to [Date & Time] with the left and right button.
The instruction are on page 21 of the user guide.
Communication error????
Blame Microsoft updates. Try using a card reader instead...works every time.
I am trying to set date time in my camera(canon sx110is). But in every power on it is reseted. Whatever date i am setting in this camera is not stored in the memory. In every power on it asking for...
You have to change the 'date battery'. Use the user manual to find its location.
Mine is Canon A520, located beside the cable link sockets. Battery is CR 1220.
Dec 16, 2008 • Cameras
1helpful
Lens cover
Hey pkg414,
You could bring the camera to a Geek Squad® precinct in a Best Buy™ store and they should be able to send it out for service, or you could contact the manufacturer and they should have a list of authorized service technicians in your area. I will also says if the camera is less than a year old the repair will probably be covered under manufacturers warranty and be no charge to you. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 15, 2008 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
