Question about Nikon N75 35mm SLR Camera
Film is stuck in kodak advantix tried a new battery and nothing happens - camera doee nothing
    Brigadier General:
  • 3,006 Answers
APS cameras are very rarely seen these days because the film loading and advance mechanism was poorly designed and engineered from the start.
Your fault is very common and given that the camera will be irreparable anyway (no spares, plus the small problem that the camera was never designed to be repaired anyway) then you need to decide whether to just chuck it away or whether to break open the camera in total darkness and manually rewind the film back into the cassette for developing.
Posted on May 15, 2010
Anonymous
  • 62 Answers
SOURCE: film is stuck in kodak advantix
your camera is stoct inside.. the michanical inside
Posted on Mar 20, 2010
I have an old Nikon Lite Touch Zoom 100 AF camera and I am having trouble loading the film. Can you use Kodak Advantix APS film in this camera or should I be using manual loading film instead?
This camera uses 35mm film, not APS film. 35mm is a larger format, giving MUCH better results, at the expense of having to manually pull the leader across to the take-up spool each time you load a roll.
Dec 29, 2010 | Nikon Lite Touch Zoom 120 ED/QD 35mm Point...
E flashing/ camera locked
Cmaera has no film or is broken. time to upgrade or find a used one since that one is not worth repairing.
Mar 13, 2010 | Kodak Advantix C650 Zoom APS Point and...
The picture lever in kodak advantix f350 is broken
The Advantics series is no longer being repaired directly by KODAK therefor the support and repairs for Advantics cameras in Europe is from a company named Johnsons Photopia: http://www.johnsons-photopia.co.uk/Contact%20Us_3.php
For more information on Advantics repairs in the US:
http://wwwuk.kodak.com/global/en/service/repair/repairCentersTraditional.jhtml
I must note that due to the price of the repair compared to a brand new digital camera that it might be a good idea to think about going digital for Christmas.
Dec 05, 2009 | Kodak Advantix F350 24mm Point and Shoot...
What kind of film do I need?
Use the regular 35 mm films, if you can find them.
Hope it helps.
Sep 11, 2009 | Minolta Dynax 404Si Film Camera
Cannon ELPH LT
The ELPH LT takes APS film, like the Kodak Advantix.
Mar 08, 2009 | Canon Elph LT 260 APS Point and Shoot...
Dont take any pictures
Change the batteries and try again.
Feb 12, 2009 | Kodak Advantix F620 Zoom APS Point and...
Stuck remaining exposure count despite new film, new film unlded
You might try closing the film compartment without film in it and press the manual rewind button. This might reset the counter circuit.
Dec 08, 2008 | Kodak Advantix 2100 Auto APS Point and...
Problems with camera display on kodak APS (something or other......)
I am having exactly the same problem (I have a T550). On the last film I shot, the only way to advance the film was to pull the battery out and re-insert it every time. When I printed that film, all the frames are blank! Kodak's FAQ about "clearing the logic" suggests a solution for that problem. 1. Turn camera off 2. Pull battery out 3. Turn camera on 4. Click the shutter approximately 6 times 5. Turn camer off 6. Repeat step 4 7. Reinstall battery I just tried that but the problem persists. I am now going to leave the battery out for several hours; maybe this will help. Otherwise, well it is time to bite the bullet and buy a digital !
Jun 21, 2007 | Kodak Advantix T550 Auto Focus APS Point...
Nikon N75 35mm SLR Camera Logo
336 people viewed this question
Top Nikon Photography Experts
Ric Donato
Jeff
Jeff
Richard C Cohen
Richard C Cohen
Are you a Nikon Photography Expert? Answer questions, earn points and help others
