I would like to mount this on the wall. There are 4 holes in the rear but any screw that I use to see if these are the mounting holes are too small. How do I find out if this is wall mountable?
Yes it is mountable. the 4 bolts are metric size is 6mm -1.0 x 40 mm
Use are large tv wall mount unit and buy the bolts seperately. I just hung mine and the
only problem I am having is I cannot remove the table top mount off the bottom of my TV
Most of these will. You san see the screw mounts on the back of the set and compare them the wall mount spand holes. I have mounted 19" RCA LCD Panels so I have got to believe this 32" should be able to mount on most universal wall mounts.
I hope this helps, Skyassoc
What type of wall mount would I need for a 32in Emerson LCD320EM9 HDTV LCD. And how do I mount it to the back of the TV. TV on back only has two holes for screws?
Yes it can as long as it has the screws in the back of the unit for the wall mount to be attached. You can call your manufacturer and retrieve the model number to the type of wall mount you desire. You can purchase a wall mount directly from manufacturer website or if you prefer can buy it from your local electronics retailer.
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
