Download drivers from http://www.ziddu.com/download/9852952/ToshibasatelliteL300drivers.zip.html and install chipset driver and modem driver.,it will work..
Link to download drivers http://www.ziddu.com/download/9852952/ToshibasatelliteL300drivers.zip.html
The SM Bus Controller is usually a driver for the chipset. You should be able to find it by going to Toshiba's website, entering your info when prompted for it, choosing the operating system that is on your computer, and then downloading and installing the Chipset Driver.
SOURCE: wifi,lan and sm bus controller driver links for f733au notebook ?
how to install driver for compac c700 laptop.
i'm format the system,then how to install this?
guna
SOURCE: SM Bus Controller
Here is a list of all the drivers for your unit. The SM bus drivers is usually contained in the chipset download file.:
http://www.csd.toshiba.com/cgi-bin/tais/su/su_sc_modItemList.jsp?moid=1310939&rpn=PSAA2U&ct=DL&BV_SessionID=@@@@1407491193.1222736688@@@@&BV_EngineID=ccceadeffhmhgeicgfkceghdgngdgnj.0
Please remember to rate other users who assist you for free :)
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Dell Inspiron 710m PC Notebook Problem
Go to "Device Manager" and look if any yellow or red alerts are being displayed next to any devices. To access the "Device Manager" go to the 'Control Panel", "Administrative Tools", "Computer Management" and select "Device Manager" located in the left side column.
If there is an alert, double click on that device to determine the problem, i.e.… device not configured, cannot start this device, etc…
It sounds like all your software drivers got blown away or can’t load. If that’s the case, try running diagnostics. Press and hold the <Fn> key while powering the system on. This will initiate a diagnostic routine to check your hardware.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
SOURCE: need to install mass storage controller,sm bus controller
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNN365E&LOC=3
There is the support site for your model, you will find the drivers you need there
Good luck M8!
Nic
SOURCE: SM Bus controller drivers for dell inspiron 6400 laptop
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid&SystemID=INSPIRONI6400/E1505
try those drivers and let me know if they dont work
