I hope that after all this time, you were able to find that code. But if you weren't, or you still have some questions, here are some steps and codes.
1. Hold down the clear TV button until all lights light up at the top of the remote 2. Punch in a 3 digit code (provided below) 3. Press the # (POUND) button 4. Try powering the tv on/off, and the volume. If one or more of these functions do not work, start over from step 1 with a different code
I hope that you have found the code already, but if not, I am here to help!!! Follow the link below, which will walk you through programing the DISH remote to that tv. Very simple process!!!!
METHOD" presse TV1 and SET button light on remote is steady enter code ...light goes out.. PRESS SET again and try. Keep trying unhtil unit can be turned on or off, then you know you have the right code. Write it on the back of the TV incase it drops out which can happen.
Change batteries?Take it aparts,clean it with Q Tips
with some rubbing alcahols in the rubbers knobs and
clean the films between the circuits board.Don't work after this.Buy a new remote at this website.1-800-remotes Factory Original.Yes,universal remotes it cheaper,but causes univeral codes,more headaches later.
Yes I have solved my problem. Thank you very much for the help. I came across a web site that gives you the TV codes so I can program my Direct remote.Thank you again.
NEED THE TV CODE FOR PROGRAMING UNIVERSAL REMOTE FOR SYMPHONIC 13" TV/VCR COMBO
