Question about KitchenAid KBMC140HSS Convection/Microwave Oven
Kitchenaid microwave oven KBMC140HSO
Microwave will not function ----beeping continiously-----An observation once power is removed for 10-15 minutes Microwave will operate normally for one cycle----------after that, this unit reverts back to a continious beeping and not opertative.
Please help!
  • 4 more comments
  • sawdust51 Oct 19, 2008
    I too have the beeping problem. PLease post the fix if done. Thanks Much!!
  • merickson Nov 24, 2008
    Hi, how much was the keypad and how hard/easy was it to replace?
  • skyetop Dec 03, 2008
    GE microwave/oven combo keeps beeping with power off
  • judy4321 Dec 26, 2008
    microwave beeps,kitchenaid KBMC140HSS0 keypad not working, no error codes, clock works
  • Anonymous May 10, 2009
    Oven keeps beeping randomly. Clock is working.
  • William Miller
    William Miller May 11, 2010
    When it goes into this "beeping" mode, does the display show any codes or anything unusual?
I started having the same problem with my KBMC140HSSO. You cannot see the error codes without disassembling the control panel (the codes are on another display that covered by the front panel). After doing so I found the error code to be F2, E3 which is "Key held down too long, or key shorted". I am ordering a replacement keypad and will report back if this fixes the problem.
Posted on May 07, 2008
  • deanc May 27, 2008
    Replacing the keypad did fix the problem.
  • Sarah Murphy Nov 15, 2011
    I am having this beeping problem as well with my KBMC140HSS0. Did you replace the switch membrane (part number 4453025) or the electical control circuit (part number 4452482). Also, how to I get the front off to access the control panel?
6ya staff
SOURCE:
Kitchenaid architect II microwave won't stop beeping
Hi Carole,
Dear you most probably have problem with electronic control board in your microwave oven.
It has to be fixed by an Electronic Technician.
If you have knowledge in Electronics then I can help you fix by yourself.
Just let me know
Regards
Ashwin
Dec 17, 2014 | KitchenAid Microwave Ovens
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Sep 23, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchenaid KCMS185JSS-3 microwave - no power
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
Sep 03, 2009 | KitchenAid KCMS185J Microwave Oven
Microwave/Convection Oven has mind of its own: turns to Crisp mode on its own.
Yes this is a touchpad issue. As you have noted the crisp button is stuck and this is the cause of this. You can try removing the keypad and push up the pressed button. If its jammed then replacing it is the only way.
Sep 02, 2008 | KitchenAid KBHC109J Convection/Microwave...
GE xl 1800 beep
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Jul 10, 2008 | GE JVM1660 Microwave Oven
Microwave will not respond to any button being pushed
The service man just left it was the 20 amp line fuse. Have one on order.
Jun 11, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
GE JVM1660 1000 Watts Microwave Oven beeps every minute
Maybe u should contact ur retailer or the manufacture helpline and tell them your problem they might be able to tell what's wrong.
Feb 28, 2007 | GE JVM1660 Microwave Oven
KitchenAid KBMC140HSS Convection/Microwave Oven Logo
1,465 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jerry Greenberg
Jerry Greenberg
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
