Sentry Fireproof Safe Logo
Posted on Mar 29, 2008
Sentry Model 1610 Won't Open
I have a Sentry Model 1610 safe with an electronic lock. Entering the factory 5 digit code gives the green proceed light but the handle won't turn and the door won't open. How can I get the door open?
  • 20 more comments
  • contacta Apr 03, 2008
  • plongmire Apr 15, 2008
    IT WORKED--THANK YOU THANK YOU.
    I WOULD HAVE RATED YOUR SOLUTION FIXYA, BUT THE COMPUTER WOULDN'T LET ME...COULDN'T FIND THE PAGE.
    The solution offered by a reader fixed my problem, but it's so hard to use the technical support service--pages don't come up and the list goes on and on. but thanks to the person who took the time to tell me a solution.
  • saftey Apr 16, 2008
    I have a Sentry fireproof safe. The numbers on the front of the safe by the door hinge are 84549 & AJ356060. I can't remember the combination. Can anyone help me?
  • beviansa Apr 23, 2008
    I have this same problem, what is the solution?
  • Kozol Apr 28, 2008
    I have a Sentry 1610 Electronic Safe. Electronic Keypad only. The battery went dead so my stored combo is useless. However, the safe came with a default stored combo. I can not find the user's guide that came with the safe as I bought it years ago. The default code was included with the documentation. Is there anyone out there that has a similar safe and do they have the default combo that was issued with it?
  • Anonymous May 14, 2008
    hello i have a sentry safe and i went to open up yesterday and it wont open up with the combination so i changed the battery and it still will not open.its a sentry safe 1610.please givew me some advise on how to open up.thank u .in mississippi.
  • Marcus Harris
    Marcus Harris May 23, 2008
    I HAVE MODEL 1610 AND IT WON'T OPEN WITH FACTORY COMBO. CAN YOU GIVE ME SOLUTION TO OPEN I HAVE CHANGED BATTERIES BUT STILL WON'T OPEN AFTER LAST NUMBER IS PUT IN
    IT SOUNDS AS IF IT GOING TO OPEN BUT IT'S AS IF THE LOWER LOCK ISS NOT RELEASING.
    THANKS,MARCUS HARRIS
  • TMoore269 Jun 08, 2008
  • robbie bachm Jun 11, 2008
    my problem is same with an Oxbow gun safe... the battery went dead while on vacation and now my combination will no longer work.... is there a code to enter to get it open ?
  • Anonymous Jun 21, 2008
    combination works but door has always been an issue getting open. I am about to take it back to costco.
  • graceyim_sg Aug 03, 2008
    I have the same problem, after changing the new battery 9V on mdl 1610,green light is on and it sound like it going to be able to open but it did no, so what should i do
  • Anonymous Sep 24, 2008
    please let me know how to open safe after wires are broken from touch pad
  • srobinson873 Oct 08, 2008
    I have the same problem on the Sentry 1610. What is the solution.
  • srobinson873 Oct 09, 2008
    DDDD
  • antennas2003 Nov 26, 2008
    iI enter the code and the green light comes on it clicks but the handle will not move
  • Anonymous Mar 18, 2014
    sentry AS479863 have key and has knob on door which I have turned both right and left
    The problem is using the code to open it open 3/4of was and donor lock and stay locked I keep narcotic perscriptipn in the
  • Anonymous Mar 19, 2014
    I need the instructions on how to open a Sentry Model V330 safe
  • Anonymous Mar 27, 2014
    have typed in code 159A green light comes on turned knob wont release have tried key turned knob still wont realese
  • Anonymous Mar 31, 2014
    battery is fine, entered factory code in wrong 3x now I am locked out.
    WE HAVE ELECTRONIC FIRE SAFE-BV-545144. WE KNOW COMBINATION BUT WHEN WE TURN KEY, ENTER COMBINATION WE GET RED ERROR LIGHT. NEED HELP NOW HAVE TO GET A CAR TITLE OUT. THANK YOU
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 21, 2008
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
28759
Points
13
I am a Safe Specialist i have been reading some of your problems and this should help there is no code if you have lost yours only the default code for the model 1610 the default code is: 77,22,09,11,64 try that if you havent changed it and with this problem with people not getting the handle open with the green light happening i suspect this is a issue with the lock mechanism i have had many of the same problems with people bringing them in when you get you safe open it and where the lock is put some lubricate on the lock regulary as the lock sticks and wont open if you havent done this then you cannot get it open see you local safe specialist and tell them what i have said and they may or may not be able to get your safe open i hope this has helped Rob Safe Specialist World.
Anonymous
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Apr 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
30831
Points
19
I'd try things in this order.
1. Replace Batteries
2. Replace Battery pack with a 9V (if it's a set of 4 AA batteries, the 9V will have more juice 9V vs 6V, and might get the job done)
3. Hit the door several times with a rubber mallet.
If you get it open, then pry off the plastic cover on the inside of the door, and spray the little locking mechanism with WD40. it seemed to work for me.
A
Anonymous
  • Billy Snokes
    Billy Snokes Feb 08, 2014
    contact me @ [email protected] i can tell you how to open but not on here
  • Valarie Niessner
    Valarie Niessner Nov 19, 2020
    can you tell me how to get the door open, my email is [email protected] i am going to try to enter the 5 digit code (whatever that is) and try again..I'd appreciate it..thank you (i also have the sentry 1610, won't open at all)
Anonymous
Level 1:
  • Posted on Jul 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
28759
Points
We have a Sentry 1610.
The green light indicated the correct 5 digit combination had been entered but it wouldn't open.
We unscrewed the battery compartment immediately below/behind the number pad and replaced the 9 volt batter.
Voila, it worked.
A
Anonymous
I dont know what model i have but you enter five digit has 3 lights when green will open.
Acouple of months ago I had the same problem and replaced the batteries and it opened fine. I guess the batteries had enough juice to work the key pad but not the lock rods!?
Renato Zorzi de Carvalho
Level 1:
  • Posted on May 24, 2023
Contributor
Level 1:
Answers
Questions
0
Helped
28759
Points
10
Ol? amigos, tenho um cofre Sentry model 1610. Eu troquei a bateria, digitei o codigo mas n?o abriu e acendia a luz vermelha. depois de algumas tentativas ele n?o responde mais. Algu?m pode me ajudar ?
haley ventura
Level 1:
New Friend:
  • Posted on Aug 10, 2015
haley ventura
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
28759
Points
Seems like you're in a pickle. I know a lot of people have had trouble opening these safes, and they have found solutions here http://www.monomachines.com/shop/info/My-Sentry-Safe-Wont-Open.html that work great!
Good Luck!
Anonymous
Level 1:
New Friend:
  • Posted on Jul 26, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
28759
Points
Had same issue where all batteries tested and had full charge. Just get rubber mallet and bang it after you get Green proceed light and work with the handle. Took about a dozen times and was able to open it. Don't forget to lubricate it (remove plastic first inside door).
Anonymous
Level 1:
New Friend:
  • Posted on Oct 24, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
28759
Points
If you have a sentry safe with an electronic lock (keypad) and a key backup, they use a magnetic type release that pops up and pushes on the manual key rod opening the safe when the 4-8 digit code is entered.
I was having a problem with my code not working. I thought the keypad and/or locking mechanism was bad. After opening it up, i saw that the electronic release was not popping up all the way. I sprayed the release with WD-40 and it works as good as new. This was for the XO55 model sentry safe.
A
Anonymous
My safe was giving the green Proceed light but the lock wasn't clicking when the code was entered. So I did as another poster suggested: replaced the 4 AA batteries in the front (slide the panel off the bottom of the keypad to get to them) and it worked fine.
It does seem like it didn't have enough juice to flip the lock even though the Low Battery light wasn't on (probably not enough juice to light up!)
A
Anonymous
I have the same problem... any answers??
Anonymous
Level 1:
  • Posted on Mar 29, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
28759
Points
Cut the bottom off of the safe.
It has 3 layers.
Thin sheet metal, cement, and plastic.
The door is the only hard place to get in.
These are meant to protect from fire, not from burglary.
3 Related Answers
Anonymous
  • 21 Answers
  • Posted on Jul 24, 2010
SOURCE: Sentry Model 1610 Won't Open
here is the customer service phone number for you. I am sure they will be able to help you. 800-828-1438
Anonymous
  • Posted on Nov 09, 2008
just keep trying and it will open. i had to try like 20 times the other day and it finally opened. good luck because these safe's are junk !
Anonymous
  • Posted on Jan 22, 2009
I have a different model but I had the same problem. Called customer service and they had me push up on the handle and enter the code. That didn't work but then they had me tap the safe with a rubber mallet 5 times above the panel and 5 times to the right of the panel. That worked for me. Hope one of those works.
I have lost the combination for my safe model V330 my model number V330 Sentry safe
  • Open your Sentry safe by typing the five-digit factory code (found in your owner's manual) on the keypad. It's always a good idea to change your combination while the safe is open, so that you don't inadvertently lock yourself out.
  • Delete any existing codes by pressing the "P" key and entering the factory code, followed by "00000." On older safes, press the "PROG" key and entering your factory code twice to delete old codes.
  • Press the "PROG" or "P" key again on your Sentry safe's keypad.
  • Enter your safe's five-digit factory code.
  • Enter a five-digit code of your choosing within 5 seconds. This is your user code. While the factory code cannot be changed, your user code can be changed as often as you like, and that should be your primary code to open the safe. Only you should know your safe's factory code.
  • Retype the user code to verify it is working, and then close the safe.
How to fix a s0607
3helpful
How to set up th ebatteries in my sentry safe DSW5781?
Locksmiths agree
1. Remove and discard the screw (if
equipped) at the base of the lock case.
2. Turn the electronic lock case to the
right (clockwise), from 12 o’clock to
2 o’clock, and remove.
• Insert 4 new AA batteries (not included) to power
this lock.
• Replace the electronic lock case and turn to the
left (to 12 o’clock) to reassemble.
NOTE: The yellow LED will light when the batteries
need to be replaced.
3. Turn the key (if your safe is equipped with a key
lock) to the right so the lock cylinder pops out.
4. Enter the factory code. When the green light appears, you
have four seconds to turn the handle down to
open. Try this several times before proceeding to
the next step.
To unlock safe:
Enter the 5-digit factory code, a pre-programmed
user code, or a pre-programmed user pin
programming instructions. When the
green LED lights you have 4 seconds to turn the
handle and open the safe.
To lock safe:
Close the door and return the handle to the
horizontal position. For greatest security, depress
the key lock (if equipped) with your finger.
9helpful
2answers
Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
8helpful
8answers
Safe codes
Sorry to say it's worthless. next time you see one charge them to haul it off.
1helpful
My sentry safe will not open after entering the code it reads "err"
You have to press the program / enter button after you enter the code How to open electronic sentry safes.
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open
1helpful
2answers
How to open my safe with the code
1helpful
Forgot how to open my fireproof lockbox
Locksmith opening instructions manual for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
Top Sentry Home Security Experts
Grand Canyon Tech
Grand Canyon Tech
john h
ADMIN Andrew
ADMIN Andrew
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
