Jenn-Air JES8850 Electric Kitchen Range Logo
Posted on May 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Jenn Air slide in electric range JES8850 - numbers 9 and 0 no longer work on the touch pad. Trying to find the part number for replacement touchpad
Anonymous
Level 3:
  • Master 949 Answers
  • Posted on May 13, 2010
Anonymous
Master
Level 3:
Answers
949
Questions
0
Helped
258573
Points
3036
Hi, could you send me the complete model and serial numbers from the tag on the range? There are some letters after the JES8850 that are needed to look up the correct parts.
Thanks!
How do I set the 24 hour clock back to 12
Press 0 (Set up options) and then 4. Then press Auto Set (on the right of the clock) to change the setting. Then press any touch pad except Cancel to exit the setup menu and save the change. (Alternatively, press 0 and 9 followed by Auto Set and another key to return all features to the Default. 12-hour time is the default for the Jenn Air range.) Jenn Air has the manuals for most of their products on their support site, http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . I looked at the manual for the JES8850AAB which is available here: http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208113P367-60.pdf. The information on setting the options is on page 12 (page 13 of the PDF). Note you'll need Adobe Reader or a similar program to access the manual.
I hope this helps.
2helpful
My 8114p732-60 control panel doesn't work only the time is displayed
Hello. We replace alot of control panels on this unit,the panel which includes the touch membrane.Not the clock behind it. Hope this helps....
2helpful
Jenn-air electric range model JES9800AAB some kypad # not working
Unless they start working again after it has a chance to dry out the touch panel will have to be replaced. This happens when excess moisture gets between the very thin layers of the membrane.
eric
Touch Pad
Hello , your problem is the switch membrain , it sends signals to your control board.
you may be able to clean the ribon cable on the control board end but it may just need a new membrain.
The switch membrain is the part all the buttons are located on and they go out often on jenn-air ranges.
let me know if you have any further questions.
Phil
2helpful
2answers
Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
1helpful
3answers
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
