Pc shuts down and is hard to start usually takes 4,5,6 or more t
Pc says to start with m/soft repair process or start normally but always shuts down in either option process. when trying to start windows normally it does the same. after many tries, finally seems to "catch" and starts. also does not let me download any security programs or system restore, even with original backup cd that came with pc. never had a problem until the other day when an apparent trojan "fake generic security" virus tried to infect.
Re: pc shuts down and is hard to start usually takes...
U need to download win-pe live cd, and burn it to a cd, boot it, and get into the live system, there you will find some utilities that can help.
the idea is, to scan the drive with a live cd, where the virus is not loaded....
Hi Adil,
Do you happen to know when this issue started? Usually restarting or shutting down phone resolve the issue. If not you may want to do reset ( soft or hard ).
When a Samsung cell phone becomes unresponsive or when the device slows to a crawl, a reset may be in order. There are two primary methods used to reset the phone. Users should always start with the soft reset when the phone locks up or programs slow down due to memory or software response issues. A soft reset is akin to a reboot of the machine and usually solves most problems without any loss of user data. A hard, or master, reset is required when the phone completely locks up and becomes unresponsive to any cellular signals. This second and more drastic reset deletes all personal data, preferences and settings so that the device is restored to the original factory configuration.
Perform a Soft Reset
Step 1 Press and hold the power button for 10 to 20 seconds.
Step 2 Release the power button and tap the "Power Off" option under the "Device Options" menu that appears. Tap "OK" to initiate the shutdown.
Step 3 Press the power button again to restart the device.
Perform a Hard (Master) Reset
Step 1 Tap the "Menu" key from the home screen and then tap "Settings."
Step 2 Go to "Privacy" and tap "Factory Data Reset" to review the Factory Data Reset information.
Step 3 Review the Factory Reset options. Place a check next to "Format USB Storage" to clear your device of user data, such as music, pictures and other account settings.
Step 4 Review the disclaimer and verify your changes before tapping "Reset phone."
Step 5 Tap the "Erase Everything" or "Yes" buttons to confirm the reset the phone to factory settings. The device initiates the restoration process to the original factory configuration.
Perform an Alternative Soft Reset
Step 1 Power off the phone. If the phone does not turn off, remove the back cover of the phone and take out the battery. Wait between 10 and 30 seconds and then replace both the battery and the cover to restart the device.
Step 2 Simultaneously hold down the power/lock keys.
Step 3 Release the keys when the Android screen appears.
Hi Adil,
Step 1
Step 2
Step 3
Step 1
Step 2
Step 3
Step 4
Step 5
Step 1
Step 2
Step 3
Always include the version of Windows in your posts.
Could have been a RAM problem if you got 4 beeps and you seem to have resolved that by reseating the modules. But the RAM error may have caused some corruption to a file on the hard drive.
Assuming the diagnostics pass, you can reboot and press F8 before Windows starts to load. Select Last Known Good. If that gets you to the desktop without errors, shut down normally and reboot normally, and you should be good to go.
You may also want to run chkdsk on the hard drive:
Click: Start>run
Type in: chkdsk C:
Click OK
Accept the offer to run chkdsk at next boot and then reboot. chkdsk will run before Windows loads. It may take a long time, depending on size of your hard drive, so be patient.
Im not sure if you are wanting to get to start-up repair or trying to get rid of it If you want to access it, Boot system and do a hard nshut down. Restart, you will have the option to Launch start up repair or to start windows normally If you are getting the option screen unwanted, this is primarily due to improper shutdown. Whenever you shut down always try to use shutdown, restart options in taskbar. If in the event you are stuck and need to do a hard shutdown try pressing Ctrl/Alt/del simultaneously to access task manager. Here you can end processes hung up or do a proper shutdown
Decide what kind of reboot you are going to do. A soft reboot is performed the way you are “supposed” to do it. For a soft Windows reboot, go to the Start menu and select “Shut Down” or “Restart.” The computer will then shut itself down. Clicking “Restart” makes it boot up without further intervention from you.
Step 2
Perform a hard reboot by pushing the computer’s power button and holding it until the computer shuts down. Wait 45 seconds and restart the computer by pushing the power button again. You may have to start up in safe mode, but that also allows you the chance to restart properly or work on programs in a safer way. This method may cause you to lose data or mess up the operation of some of your programs. But it may be the only option if your computer's hard drive is frozen.
Step 3
Power down all of the computer's components. Shut off all of the peripherals you have attached to your computer, and disconnect the cables. Then, plug all of the peripherals back in, and restart your computer. This can often solve problems with your hard drive.
Step 4
Purchase and install a program such as Drive Reboot Restore PC 6.0 that streamlines the hard drive reboot process. These applications help prevent the problems that can develop after repeated computer use. They also ensure that your hard drive maintains the configuration you want each time you turn it on.
Step 5
Investigate what the problem may be with your hard drive. Because of its delicate nature, your hard drive can very easily be thrown off.
Run an Error check on your computer. Process takes anywhere from 1 to several hours, depending on hard drive size, files on computer and number of errors needing to be fixed.
Manual steps to run Chkdsk at the command prompt
loadTOCNode(3, 'moreinformation');
Click Start, and then Run.
In Open, type cmd, and then press ENTER.
Use one of the following procedures:
To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
Note If one or more of the files on the hard disk are open, you will receive the following message:
Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
Occasionally you may need to reset your Pocket PC Phone. A normal
(or soft) reset of your device clears all active program memory and
shuts down all active programs. This can be useful when the device is
running slower than normal, or a program is not performing properly. A
soft reset is also necessary after the installation of some programs.
If a soft reset is performed when programs are running, unsaved work
will be lost. To perform a soft reset: o Use the stylus
to lightly press and hold the RESET button on the bottom of your
device. The device restarts, and then displays the Today screen. Warning! Always turn off your device before performing a soft reset or installing/replacing the battery. You
can also perform a hard reset (also known as a full reset). A hard
reset should be performed only if a normal reset does not solve a
system problem. After a hard reset, the device is restored to its
default settings-the way it was when you first purchased it and turned
it on. Any programs you installed, data you entered, and settings you
customized on the device will be lost. Only Windows Mobile software and
other pre-installed programs will remain To perform a hard reset:
Press
and hold both soft keys on the device. Keep these keys pressed, and at
the same time, use the stylus to lightly press and hold the RESET
button on the bottom of your device.
Release the
stylus but keep the soft keys pressed when you see the following
message on your device screen. "Do you want to erase all user data and
restore to manufacture default?" will appear.
Slide open the hardware keyboard, and press R to restore to factory default or press X to exit the hard reset process.
Hope this helps, let me know if I can help you with anything else. JimmyC
Here are the possibilities:
1) Hard drive has too many read element failures
or
2) windows system files needs repairing or operating system needs re-installation.
Try these:
1) Reboot your pc and get into BIOS. Then set to default setting and save. Then try booting. If this does not fix issue, take next step.
2) Insert the operating system cd and go thru the repair process.
