Emerson MW8102SS 1100 Watts Microwave Oven Logo
Anonymous Posted on May 11, 2010
Chipping/peeling rusting paint in interior under carousel
What do I do; this is only 18 mos old
Anonymous
Level 3:
  • Master 949 Answers
  • Posted on May 11, 2010
Anonymous
Master
Level 3:
Answers
949
Questions
0
Helped
258576
Points
3036
Scratches and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord and remove the turntable and the support that is under the turntable. Clean the surface of the support wheels or any other part that rubs on the oven cavity.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
Testimonial: "thank you so much! I would have never thought of that and thrown out my new microwave!!!"
2answers
Panasonic Inverter microwave, paint starting to flake under the ring.What can be done?
dont ever in future buy a microwave with a painted interior as it will always peel.......better to buy a stainless steel one.i don't know if there is a special paint you can buy but if you look on the internet you will find one.
1helpful
2answers
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
I have a sharp household microwave oven model R410LK - I am not sure if it is safe as I have paint chips coming off the interior roof and floor of this microwave. The floor now has a black ring on it...
The rusted areas will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Then be sure to promptly clean up any spills or steam after using the oven.
11helpful
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Paint has chipped off bottom of MW
Moisture accumulation can sometimes be caused if the cooling fan is not running properly or if the vents in the back are blocked or there is not enough free space around the sides and back of the microwave.
One thing that helps is to keep the door open a few minutes after using it and to wipe down the inside after use.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
4helpful
Inside finish is peeling off
No, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing, which can be messy.
3helpful
PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Otherwise, you can have rust and arcing.
1helpful
3answers
Peeling interior
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
You can sand the peeled area, even the rusted area in most cases, clean them squeaky dry, and repaint with high-temperature appliance paint available from places liek Wal-Mart, home improvement centers, and appliance parts stores.
No need to replace the microwave if you can clean and paint it properly.
Top Emerson Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
