Question about Blodgett DFG-100 Gas Single Oven
I need a wiring driagram for blodgett DFG100/200 w/cook. unit does not operate. it has a johnson G770-mgc3 module control, when testing i found 120volts being supplied to the module from the small circuit board. I am not sure if the cb is bad, causing the high voltage instead of low voltage to the module.
  • 1,300 Answers
Http://www.blodgett.com/service-training/dfg-100-training/
go to this website for interactive video on sequence of operation and controls operation.
Posted on Mar 19, 2018
    Top Expert:
  • Blodgett Master
  • 55,370 Answers
Request the wiring diagram directly from Blodgett.
Posted on Jan 06, 2018
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: athens controls inc board for old blodgett oven (gas)
Athena still sells this product as a ttc001
call me at 610-729-1032
Posted on Jan 08, 2009
Charles Jerney
  • 12 Answers
SOURCE: My company has Blodgett Gas
The serial number is under the left side door behind the cover. Open the doors take out the two phillips head screws which go into the top of the lower cover, one on each end just inside the door hinge, the lower cover will remove to the front.
Posted on Dec 09, 2011
I have a blodgett zephaire gl oven. unit kept buring up 24v transformer, was old bad centrifical switch in motor. I replaced motor with brand new one, unit still buring up 24v transformer.....why ?
A short somewhere causing it to overamp. Put a 3amp inline fuse on the secondary side (24v side) on the hot wire. This will save the transformer and blow the fuse not the transformer. The centrifugal switch prolly wasn't bad. So I would trace the wire coming off transformer and look for bare wire or loose wires. Anything that would cause a short
May 04, 2016 | Blodgett Ovens
Timer not working. How do we set it for manual operation?
Timer is independent of cooking operation. Only switches on buzzer.
Jan 09, 2016 | Blodgett Model Mark V Single Electric Oven
Blodgett oven mark v 111 can cool down but not cooking
door switch need to be checked or repalce. you can put 2 wires connect together and turn on see motor is running, if it run that mean switch is bac...good luck.
Jun 05, 2014 | Blodgett Model Mark V Single Electric Oven
Is there such a thing as a descaling unit for a blodgett combi oven model bc14g/ab
These combi ovens are so prone to problems if you do not have descaling filter system hooked to the COLD water supply (the only water that should be fed to this unit) for your generator inlet. The other water hookup is for your condensate drain (condenses steam leaving cook chamber headed down the drain) and it does not need to be filtered but, also needs to be COLD. These decaling units are quite pricey but, a service call to replace the generator (boiler in laymens terms) will cost 3 times as much & the unit will be down for days waiting on parts. Call Blodgett w/ your model # & talk w/ technical service & ask their recomendation. They can be reached @800-331-5842 & follow the prompts. Depending on your water conditions it is still recomended to descale the unit on a regular basis using a QUALITY descaler (not the junk you buy from Sysco or Dollar general) Cleveland descaler is the BEST.
Jul 24, 2009 | Blodgett Combi® BC-142G Stainless Steel...
I can't find air finger configuration for Blodgett MT-3870
Go here find what you seek. Great Co.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Mar 18, 2009 | Blodgett MT1828G Oven
Blodgett oven
Go here to find what you seek. They are a Great Co. ready to help
BLODGETT
Nov 11, 2008 | Blodgett Model Mark V Single Electric Oven
Blodgett oven
if you only have 3 wires to the element it doesnt matter how there hooked up.
Aug 07, 2007 | Blodgett (ZEPHAIREG-DOUB) Double Oven
Blodgett DFG-100 Gas Single Oven Logo
384 people viewed this question
Top Blodgett Ovens Experts
Dennis Boxerman
Marvin
Marvin
Are you a Blodgett Oven Expert? Answer questions, earn points and help others
