When caller dials long distance with calling card, gets error saying that numbers dialed are not valid- three out of four attempts. phone is going through Cisco switch via analog gateway. When caller goes to VOIP phone, call goes rigth through. Any ideas?? Is 8004 pulse or tone?
SOURCE: How do I call forward this phone to my cell?
Forwarding is through the plan provider and part of the voice mail system.
SOURCE: Cal do you use the
In order to set call forwarding on this telephone, must first have the feature CFV (Call Forward Variable) on in the line. This feature can be provided by the telephone service provider.
A typical feature code for this is *72 to activate CFV and *73 to deactivate.
You can program these features on the M9316 telephone by do the following:
CFV activate
1) Press the SAVE key.
2) Then select the key where you want to program the feature.
3) Then enter *72 (optional: plus the telephone number of where you want the call to forward to).
4) Press SAVE twice.
CFV deactivate
2) Then select another key where you want to program the feature.
3) Then enter *73
Be sure and label your buttons.
To use go off hook and press the key you just programmed.
SOURCE: I have a 480i phone.
If this is a new phone that you just set up, be sure that you've looked at your dial plan and have it configured correctly.
